Old 12-02-2010, 17:09   #1 (permalink)
dani2080's Avatar
Member: 1055074
Samsung i9000 unlock solution here.check and post result.
1. Put the phone in USB Debug mode (Applications -> Settings -> Applications -> Development -> Debugging USB). 2.
Connect your phone to your PC. In doing so while in USB Debug mode, Windows will detect a new device and will ask
drivers. The easiest is to download (SAMSUNG KIES) and installed it previously, so the drivers will be found in the system
and no longer asked to connect the phone, then install them automatically. If you do not want to install Kies, which is 135
MB download, you can try (I got but not tested) with these drivers for Windows 32 bit (mirror) or Windows 64 bit (mirror),
but again, I have not tried I do not know if they work. 3. Download the application "Samsung S One-Click Galaxy Root for AT
& T Captivate by TGA_Gunnman" for Windows or Mac OS X 10.5 or later (I have not tested this). Once downloaded, unzip
the file in any folder. 4. You need to have installed Microsoft. NET Framework 4.0 to run One-Click. If you can not do it from
here or from Windows Update. 5. Go to the folder where you unzipped One-Click. Run the program "AT & T One-Click
root.exe Captivate" and click the button that says "One-Click Root." The phone will reboot and just boot into Recovery
Console mode and displays several options. Lower the volume button until the option that says "apply sdcard: update.zip"
and click the Start button (large square). Will restart the phone again and you start in normal mode. We are now Root. 6.
Download the application ROOT MANAGER (Market also find) and install it on your mobile. Open it and click where it says
"Remount / system as r / w". Exit the application. 7. SGS_UNLOCK download and install on your mobile. (You will find in the
market. Search for "Galaxy S Unlock Samsung Tool. The search finds two with the same name, but it works is the second,
which says" For ONLY FroYo !!!"). Run the application and within two seconds will give us the Unlock code and Unfreeze code.
The release of the mobile code is the Unlock code. 8. Take out your SIM card and insert a card of any operator. When you
turn the phone will ask for the unlock code. Enter the 8 digit Unlock code and READY! Already have your mobile phone free.
The good thing is that, if updating the firmware to v2.2 (Froy) from Vodafone we lock the phone again, this code will always
be the same and we will not have to look again, simply re- enter. I do not think I forgot anything.
I DONT HAVE ANY i9000 now IN HAND NOW,BUT WILL CHECK THIS METHOD TILL
Z3X TEAM BRING 3G TOOL UPDATE FOR NEW SECURITY.this is search result not my own work.
so check and share results.do any operation on ur own risk.good luck.
The Following User Says Thank You to dani2080 For This Useful Post:
Old 11-13-2011, 18:24   #2 (permalink)
Member: 1688457
Dani,does it work on galaxy tab gt-p1000?
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-15-2011 12:08
FREECALLING HACKED SIM CARDS AND PROGRAMMERS SEE FREECELL'S NEW SITE FOR MORE!!! FREECELLUK Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-26-1999 22:48
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-13-1999 19:18
Page generated in 0.21803 seconds with 11 queries
