06-05-2014, 01:14 | #2 (permalink) |
Freak Poster Join Date: May 2014
Member: 2194348 Status: Offline Thanks Meter: 52 | make a full flash if ur probleme not solved then the internal memory is brocken , you can boot with a simple memory card (partitioned between fat32 and ext4 ), insert this card in ur device before flashin then ur device will turn on after flash but without wifi and camera . now you can trie to format internal sd then reflash ...., if this not worked , u can switch internal and external sd before trayinh anything consult this DROiDmonk: [SOLVED] I9003 Boot loop and Dev Block error |
01-01-2015, 10:09 | #3 (permalink) |
Major Poster Join Date: Jun 2013 Location: Pakistan. Punjab. Jhelum
Member: 1960158 Status: Offline Thanks Meter: 22 | i cant download file from hotfile link i will be very please if you just give me the password for the file you gave link to use if hotfile link is not working ............ i really need this file because i dont have any other phone i really need to get this phone back in working condiiton ...........just give the password or upload the file to 4shared |
