01-10-2013, 16:17 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: morocco
Member: 587405 Status: Offline Sonork: 100.1681610 Thanks Meter: 151 | Samsung i9070 unlock done Selected port: COM5 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I9070 Android version: 2.3.6 Product code: GT-I9070HKAATL Phone version: I9070XXLE2 PDA version: I9070XXLE2 CSC version: I9070OXXLD4 IMEI: Unknown Checking Super user right... false Rooting phone, please wait... OK Checking Super user right... true Reading data from phone... OK Now connect phone to UART cable Checking phone at COM5 OK Bypass MSL... OK Unlocking... OK Unlock done Codes set to 00000000 Done with Samsung Tool v.13.5 Done with Samsung Tool v.13.5 |
01-10-2013, 19:57 | #5 (permalink) | |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
BR. Arsalan gsm2000. | |
03-16-2013, 21:19 | #7 (permalink) |
Freak Poster Join Date: Oct 2010 Location: Morocco
Member: 1421995 Status: Offline Sonork: 1001640545 Thanks Meter: 56 | Selected model: I9070 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I9070 Android version: 2.3.6 Product code: GT-I9070HKAATL Phone version: I9070BULE2 PDA version: I9070BULE2 CSC version: I9070ATLLE1 IMEI: Unknown Checking Super user right... true Reading data from phone... OK Now connect phone to UART cable Checking phone at COM3 OK Bypass MSL... OK Unlocking... OK Unlock done Codes set to 00000000 Done with Samsung Tool v.14.1 Done with Samsung Tool v.14.1 |
03-23-2013, 14:34 | #8 (permalink) | |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | Quote:
09-02-2013, 21:58 | #10 (permalink) |
Member: 587405 Status: Offline Sonork: 100.1681610 Thanks Meter: 151 | instruction Samsung I9070 ROOT ... 1. Download GT-I9070-root.rar, and extract it somewhere on you local disk. 2. From stuff you just extracted run program Odin3 v1.83.exe 3. Then open Settings in your phone, go to Aplications -> Development and check USB Debugging and Allow mock locations. Both needs to be Checked (Selected). 4. Turn off phone and turn it back on into Download mode, like this press Volume Down + Home button + Power button, wait untill some "strange" screen appers, put in usb cable and choose continue. 5. Now wait until Odin recognize your phone. It can take a while first time, if you have problems search for samsung drivers on the internet, 6. Under PIT file browse for GT-I9070_EUR_XX_8G_20111220_KL6.pit, you have extracted this file before. 7. Under PDA choos rootkernel.tar.md5. 8. Then check what options are checked (Selected), be sure to UNCHECK (remove selction) Re-Partition, Flash Lock, Phone EFS Clear, Phone Bootloader Update! Only Auto Reboot and F.Reset Time should be checked (Selected) 9. When this is set just press Start and wait for phone to reboot. 10. Now repeat steps from 4 to 9, with one exception at step 7 now choose xxld1.tar.md5. 11. Download and install Superuser or SuperSU aplication from market and enjoy the rooted phone! And you must also download Busybox to install busyboxbinary. [Recommended way] Or you can use Superoneclick, this tools push the Superuser aplication to /system/app and it installs busybox binary. Just search this tools on XDA. Voila your phone should now be rooted. GT-I9070_root.rar thx |
The Following User Says Thank You to atiq022 For This Useful Post: |
09-16-2013, 01:02 | #11 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1969625 Status: Offline Thanks Meter: 1 | yo tengo la micro-box , y el cable uart que me pide me genera todo el proceso de liberacion directa y me sale que cuando me pida codigo de desbloqueo le ponga (00000000) le pongo otro chip de otra compaņia y no reconoce el codigo espero y me puedan ayudar. saludos |
12-12-2013, 17:35 | #12 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Poland, Wroclaw Age: 50
Member: 67562 Status: Offline Sonork: none Thanks Meter: 89 | I have Advance with I9070XXLQE_I9070OXXLQE_HOME.tar.md5 - it is XEO Poland, non branded. I need to root it to unlock. After downgrade to I9070XXLD1_I9070XXLD1_I9070OXFLC2_HOME.tar.md5 phone freeze with logo, can't enter hard reset... |
12-13-2013, 08:36 | #13 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Hungary, Győr Age: 46
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | why downgrade it? Just unlock it on 4.1.2. Its simple: flash back to 4.1.2. Use MMC card to root it with root.zip, than unlock. simple. |
