07-10-2013, 01:48 | #1 (permalink) |
Junior Member Join Date: Jun 2004 Age: 45
Member: 70300 Status: Offline Thanks Meter: 1 | Samsung I9100 4.2.2 change IMEI Count supported models - 302 Starting ADB Server... OK Checking ROOT... TRUE Checking EFS... Present Rebooting... OK Waiting For Reboot Finish... OK Rooting Phones... Error Done with Samsung Tool ver 12.2 |
07-10-2013, 08:14 | #3 (permalink) |
Freak Poster Join Date: Mar 2012 Location: somewhere in world Age: 37
Member: 1738848 Status: Offline Sonork: 100.1640328 Thanks Meter: 505 | bro 1st of all if u want to repair imei @ v 4.1.2 then root it with SRS then repair imei .... other wise 2nd procedure is hear... complit procedure.... 1] download u1_02_20110310_emmc_EXT4.pit 2] download file I9100XEKE2_I9100XXKDJ_I9100OXEKE1_HOME 3] download Odin3 v1.85 these all files can be downloaded 4m ufs server. procedure.... 1] open odin 2] check on re-partition,auto reboot,f.reset time 3] select pit file---> u1_02_20110310_emmc_EXT4.pit 4] select pda file---> I9100XEKE2_I9100XXKDJ_I9100OXEKE1_HOME 5] put handset in download mode (volume down+ home+power key) and connect to pc 6] start flashing... after flashing...handset alive...and use z3x v12.7 to rebuild imei. press thanks if it works 4 you... |
07-10-2013, 09:51 | #4 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Quote:
