04-23-2013, 08:11 | #1 (permalink) |
Freak Poster Join Date: Oct 2012 Location: Gsmhosting Forum
Member: 1832100 Status: Offline Thanks Meter: 63 | Samsung i9100 Emergency Calls Only Samsung i9100 Emergency Calls Only ( Android Version 4.1.2 ) I Try Unlock But Unlock Problem First: UART and USB settings: enter UART mode with *#9090# and select "Log via UART" then enter *#7284# and select "UART MODEM" and select "USB PDA". Now Windows ask normal samsung drivers! Then: -power on phone -go to MENU==>SETTING==>Developer Options==> Tick USB DEBUGGING Here is Screen Short : How to Solve This Problem ...? |
04-23-2013, 08:26 | #3 (permalink) | |
Freak Poster Join Date: Aug 2007 Location: in iOs
Member: 563648 Status: Offline Sonork: 100.1594523 Thanks Meter: 87 | Quote:
Flash 2.3.6 firmware then root after unlock | |
04-23-2013, 10:31 | #4 (permalink) | ||
Member: 1832100 Status: Offline Thanks Meter: 63 | Quote:
Pls Share How to Correct Rooting Procedure & Files - i9100 v4.1.2 i Root This File (MyGKernelV1.1.1_CWM5.tar) But After Only Samsung Logo How to Fix This Problem ..! | ||
04-23-2013, 10:35 | #5 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | Phone used 4.2.1 jelly os you can root the phone first then unlock it NOW SAMSUNG LOGO ONLY? OK DONT WORRY DONT DOWNGRADE FIRST TRY TO HARD RESET(WIPE DATA) STILL SAME LOGO ONLY DOWNGRADE THE PHONE 2.3.6 THEN ROOT AGAIN(CF-Root-SGS2_UH_UVC_LPK-v5.5-CWM5) AND UNLOCK WITH Z3X ENJOY |
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post: |
04-23-2013, 11:06 | #6 (permalink) |
Member: 563648 Status: Offline Sonork: 100.1594523 Thanks Meter: 87 | 4.1.2 Cant do perfect unlock, Better 2.3. ....... but in logo you check recovery and wipe if ok and same in logo Flash same vershion before you flash 4.1.2 Now ok ? Flash 2.3.6 firmware I prefer I9100JPLPC_I9100OJPLP9_OJP ( pda,modem,csc ) and root switch on mobile connect cable press unlock |
The Following User Says Thank You to praji For This Useful Post: |
04-23-2013, 12:33 | #7 (permalink) | |
Member: 1832100 Status: Offline Thanks Meter: 63 | i9100 Unlock Ok , But After Emegency Calls Only Quote:
I Flash This Firmware - I9100JPLPC_I9100OJPLP9_OJP After Unlock Done But Same Problem Show Emergency Calls Only Selected model: I9100 Selected port: Selected port speed: 115200 Searching Samsung modem... detected COM474 Reading phone info... Model: GT-I9100 Country code: XSG Cal date: - Factory SW: I9100JPLPC Unique number: CVY19406F6D688E Memory phone: - Software version: I9100JPLPC/I9100OJPLP9/I9100XXLPW/I9100JPLPC IMEI: 358533051051892 Product code: XXXXXXXXXXXXXX Done with Samsung Tool v.14.2 Selected model: I9100 Selected port: Selected port speed: 115200 Reading phone info... Model: GT-I9100 Android version: 4.0.3 Product code: Not Active Phone version: I9100XXLPW PDA version: I9100JPLPC CSC version: I9100OJPLP9 IMEI: Unknown Checking Super user right... true Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.14.2 How to Solve my Samsung i9100 Emergency Calls Only Problem | |
The Following User Says Thank You to FORUM-FON For This Useful Post: |
05-24-2014, 12:36 | #9 (permalink) |
No Life Poster Join Date: Nov 2009 Location: pakistan Age: 35
Member: 1164608 Status: Offline Sonork: 100.1650273 Thanks Meter: 105 | yes tested with version 17.5 mine working. Selected model: I9100 Selected port: Selected port speed: 115200 Searching Samsung modem... not found Done with Samsung Tool v.17.5 Selected model: I9100 Selected port: Selected port speed: 115200 Searching Samsung modem... detected COM178 Reading phone info... Software version: I9100XWLSJ/I9100XXLS8/I9100OXXLS7 IMEI: 004999010640000 Done with Samsung Tool v.17.5 Selected model: I9100 Selected port: Selected port speed: 115200 Waiting ADB device... OK Reading phone info... Model: GT-I9100 Android version: 4.1.2 Product code: Not Active Phone version: I9100XXLS8 PDA version: I9100XWLSJ CSC version: I9100OXXLS7 IMEI: 004999010640000 Phone S/N: 00000000000 Checking Super user right... true Reading nv data... OK Checking magic... OK Running zTool, please wait... OK Writing nv data... OK Rebooting phone... OK Repair done Done with Samsung Tool v.17.5 Selected model: I9100 Selected port: Selected port speed: 115200 Searching Samsung modem... not found Done with Samsung Tool v.17.5 Selected model: I9100 Selected port: Selected port speed: 115200 Searching Samsung modem... detected COM178 Reading phone info... Software version: I9100XWLSJ/I9100XXLS8/I9100OXXLS7 IMEI: 004999010640000 Done with Samsung Tool v.17.5 Selected model: I9100 Selected port: Selected port speed: 115200 Waiting ADB device... OK Reading phone info... Model: GT-I9100 Android version: 4.1.2 Product code: Not Active Phone version: I9100XXLS8 PDA version: I9100XWLSJ CSC version: I9100OXXLS7 IMEI: 004999010640000 Phone S/N: 00000000000 Checking Super user right... true Reading nv data... OK Checking magic... OK Running zTool, please wait... OK Writing nv data... OK Rebooting phone... OK Repair done Done with Samsung Tool v.17.5 Selected model: I9100 Selected port: Selected port speed: 115200 Waiting ADB device... OK Reading phone info... Model: GT-I9100 Android version: 4.1.2 Product code: Not Active Phone version: I9100XXLS8 PDA version: I9100XWLSJ CSC version: I9100OXXLS7 IMEI: 354654658798794 Phone S/N: 00000000000 Checking Super user right... true Reading nv data... OK Checking magic... OK Running zTool, please wait... OK Writing nv data... OK Rebooting phone... OK Repair done Done with Samsung Tool v.17.5 Selected model: I9100 Selected port: Selected port speed: 115200 Searching Samsung modem... detected COM178 Reading phone info... Software version: I9100XWLSJ/I9100XXLS8/I9100OXXLS7 IMEI: 358150047105920 Done with Samsung Tool v.17.5 Last edited by aquariesirfan; 05-24-2014 at 12:42. |
07-02-2014, 11:55 | #10 (permalink) |
Junior Member Join Date: Jul 2014 Location: NARKATIA Age: 29
Member: 2214789 Status: Offline Thanks Meter: 1 | Selected model: I9100 Selected port: COM32 USB Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I9100 Android version: 2.3.5 Product code: GT2I9100RWAXSG Phone version: I9100XXKI4 PDA version: I9100JPKJ2 CSC version: I9100OJPKJ1 IMEI: 354886456523822 Phone S/N: 00000000000 Checking Super user right... false Rooting phone, please wait... OK Checking Super user right... true Reading nv data... OK Checking magic... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.17.2 |
The Following User Says Thank You to vishal jack For This Useful Post: |
12-01-2014, 12:28 | #11 (permalink) |
Freak Poster Join Date: Sep 2013 Location: PaKiStAn & KSA
Member: 2023768 Status: Offline Sonork: 100.1661054 Thanks Meter: 76 | i9100 emergency call only done go hare to my post frist do repair all and inei also http://forum.gsmhosting.com/vbb/f453.../#post10710848 |
