02-07-2017, 11:33 | #1 (permalink) |
Insane Poster Join Date: Sep 2011 Location: rusia
Member: 1656416 Status: Offline Thanks Meter: 23 | Samsung i9505 flashing success Code: FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: GT-I9505 Software version: 27.7 File analysis... Ok Total file size: 0x9DB84024 (2523 Mb) Searching USB Flash interface... COM24 detected Setup connection... Ok Set PIT file... Ok Reading PIT from phone... Ok Sending aboot.mbn... Ok Sending sbl1.mbn... Ok Sending sbl2.mbn... Ok Sending sbl3.mbn... Ok Sending rpm.mbn... Ok Sending tz.mbn... Ok Sending boot.img... Ok Sending recovery.img... Ok Sending persdata.img.ext4... Ok Sending system.img.ext4... Ok Sending modem.bin... Ok Sending NON-HLOS.bin... Ok Sending cache.img.ext4... Ok Sending hidden.img.ext4... Ok Flashing done (time - 00:08:36) Done with Samsung Tool PRO v.27.7 |
The Following User Says Thank You to bs123 For This Useful Post: |
