03-17-2014, 15:34 | #1 (permalink) |
Junior Member Join Date: Jun 2012 Location: Divinópolis MG
Member: 1776711 Status: Offline Sonork: 100.1623769 Thanks Meter: 38 | Samsung I9505 imei not repair z3x Selected model: I9505 Selected port: COM224 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device ... Please, allow USB debugging on phone ... OK Reading phone info ... Model: GT-I9505 Android version: 4.3 Product code: Unknown Phone version: Unknown PDA version: I9505VJUEMK8 CSC version: I9505ZTOEMK8 IMEI: null spent 2ms Phone S / N: Unknown Super checking user right ... true MMCBLK backuping OK ... Checking phone at COM224 not found Done with Samsung Tool v.17.2 Done with Samsung Tool v.17.2 anyone have a solution for this problem Thanks in advance |
03-17-2014, 15:59 | #3 (permalink) |
Member: 1776711 Status: Offline Sonork: 100.1623769 Thanks Meter: 38 | the code * # 7284 # does not work Selected model: I9505 Selected port: COM224 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-I9505 Android version: 4.3 Product code: Unknown Phone version: Unknown PDA version: I9505VJUEMK8 CSC version: I9505ZTOEMK8 IMEI: null spent 1ms Phone S/N: Unknown Checking Super user right... true Backuping MMCBLK... OK Checking phone at COM224 not found Done with Samsung Tool v.17.2 when he asks the cable z3x it's a mistake notice of security policy |
03-17-2014, 16:18 | #5 (permalink) |
Freak Poster Join Date: Feb 2012 Location: india Age: 34
Member: 1718138 Status: Offline Sonork: 100.1640303 Thanks Meter: 35 | bro tri this and rply - Cable UART C3300K - Select com port box in ST software - Press *#7284# and select "Modem" (Only show one option interface "UART") *default setting: "PDA" - Press *#9090# and select "4 - DM over UART" *default setting: "DM/DUN over HS-USB" - Press "Unlock" |
The Following User Says Thank You to karan verma For This Useful Post: |
03-17-2014, 16:31 | #6 (permalink) | |
Member: 1776711 Status: Offline Sonork: 100.1623769 Thanks Meter: 38 | Quote:
03-17-2014, 20:53 | #9 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,439 | Code: Phone version: Unknown 2 find an external tool to reset the efs. imei 0049 otherwise it is a hardware issue 3 repair the imei |
03-17-2014, 22:25 | #11 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
03-22-2014, 02:30 | #13 (permalink) |
Freak Poster Join Date: Jan 2004 Age: 45
Member: 49428 Status: Offline Thanks Meter: 45 | Your efs is gone or no value... you might get lucky if you still have original IMEI and just write it in. Select new security and follow help using micro usb. The UART doesn't work anymore because cannot fully switch to UART in samsung menus. |
