09-12-2015, 04:27 | #1 (permalink) |
Freak Poster Join Date: May 2012
Member: 1763380 Status: Offline Thanks Meter: 86 | samsung j100h read code no need root Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: SM-J100H Software version: 22.5 Searching Samsung modem... detected COM116 Reading phone info... OK Model: SM-J100H Version: J100HXXU0AOF2/J100HOJV0AOF2/J100HXXU0AOF2/J100HXXU0AOF2 Product code: SM-J100HZWDKSA Phone S/N: R51G72FXX6L Imei: 3528------------ Unique number: C018734DA6D62 Reading codes... OK Please wait, calculating codes... OK (time - 00:02:50) Freeze code: 72617519 NET lock: 90864680 For check lock status: *#7465625# Done with Samsung Tool PRO v.22.5 thanks z3x |
The Following User Says Thank You to den fatih For This Useful Post: |
