04-22-2017, 07:18 | #1 (permalink) |
Insane Poster Join Date: Jun 2014 Location: Kumarkhali.Kushtia Age: 35
Member: 2211420 Status: Offline Sonork: 100.1651090 Thanks Meter: 32 | Samsung j106B Unlock z3x Done UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: SM-J100ML/DS Software version: 24.3 Searching Samsung modem... detected COM28 Reading phone info... OK Model: SM-J106B Version: J106BDXU0APL3/J106BOLB0APL2/J106BDXU0APJ2/J106BDXU0APL3 Product code: SM-J106BZDDXME Phone S/N: RV1J30Z8HWW Imei: 355002085673306 Unique number: C8G0134980E6934 Reading codes... OK Please wait, calculating codes... OK (time - 00:03:22) Freeze code: 31608294 NET lock: 94131470 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# |
The Following User Says Thank You to Ar.Sohan For This Useful Post: |
