06-23-2017, 17:23 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Dhaka mirpur-1 Age: 38
Member: 577653 Status: Offline Thanks Meter: 235 | Samsung j120a unlock problem Selected model: SM-J120A Software version: 28.2 Waiting ADB device... Ok Reading phone info... Model: SAMSUNG-SM-J120A Android version: 6.0.1 Product code: SM2J120AZWCATT Phone version: J120AUCS3AQE1 PDA version: J120AUCS3AQE1 CSC version: J120AATT3AQE1 CSC country code: USA CSC sales code: ATT HW version: REV0.3 Phone SN: R58J5755D0D Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2017-05-01 RF cal date: 20170531 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Reading data... Ok Detecting MODEM... Ok Reading MODEM... Exception: Access violation at address 0040707F in module 'SamsungToolPRO.exe'. Read of address 7F580520 Done with Samsung Tool PRO v.28.2 |
06-24-2017, 00:53 | #2 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
06-24-2017, 09:18 | #4 (permalink) |
Freak Poster Join Date: Apr 2011
Member: 1554684 Status: Offline Thanks Meter: 9 | sir reading code is ok but device not accepting the generated code. here is the log, Searching Samsung modem... detected COM5 Reading phone info... Ok Model: SM-J120A AP version: J120AUCU2AQC1 CSC version: J120AATT2AQC1 CP version: J120AUCU2APJ2 Product code: SM2J120AZWBATT Phone SN: R58HC5YECPE Unique number: CFN00C75DB211B3 Reading IMEI... Ok IMEI: 353118086320077 (SIGN: OK) Checking hash file... Ok Reading data from phone... Ok Modem board: SHANNON308 HWID: 02 7C 58 24 E7 4A EB A3 1F 95 F1 CE BF EC 67 AA Reading NV data... Ok Checking NV data... Ok Calculating... Ok Please wait, calculating codes... OK (time - 00:00:02) Freeze code: 51806191 NET lock: 03734556 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.27.7 |
06-25-2017, 05:03 | #5 (permalink) | |
Member: 577653 Status: Offline Thanks Meter: 235 | Quote:
09-11-2017, 09:13 | #6 (permalink) |
Junior Member Join Date: Jun 2014 Location: Heart
Member: 2208050 Status: Offline Sonork: Rkdanish(1656528) Thanks Meter: 16 | UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-J120A Software version: 29.2 Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-J120A Android version: 6.0.1 Product code: SM2J120AZWCATT Phone version: J120AUCU3AQE1 PDA version: J120AUCS3AQE1 CSC version: J120AATT3AQE1 CSC country code: USA CSC sales code: ATT HW version: REV0.3 Phone SN: R58J70Z4QZF Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2017-05-01 RF cal date: 20170706 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 59 12 4A E5 59 EB F5 6F 53 03 1A 19 BD 9E D7 DF Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.2 |
