02-11-2017, 06:55 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: india Age: 40
Member: 464543 Status: Offline Sonork: 100.1622465 Thanks Meter: 152 | samsung j120w Reading data from phone... error (0) To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-J120W Software version: 27.7 Waiting ADB device... Ok Reading phone info... Model: SM-J120W Android version: 6.0.1 Product code: SM-J120WZKARWC Phone version: J120WVLU2AQA1 PDA version: J120WVLU2AQA1 CSC version: J120WOYA2AQA1 CSC country code: Canada CSC sales code: RWC HW version: REV0.1 Phone SN: R58HB07VGCY Chip name: EXYNOS3475 Modem board: SHANNON308 RF cal date: 20161102 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.27.7 |
