01-16-2018, 18:39 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Nigeria Lagos
Member: 1014618 Status: Offline Sonork: 100.1637137 Thanks Meter: 110 | j701f unlock error To unlock: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' for direct unlock. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Unlock Selected model: SM-J701F Software version: 30.4 Waiting ADB device... OK Reading phone info... Model: SM-J701F Android version: 7.0 Product code: SM-J701FZDDINS Phone version: J701FXXU2AQK2 PDA version: J701FDDU2AQK2 CSC version: J701FODD2AQK2 CSC country code: India CSC sales code: INS HW version: MP 0.400 Phone SN: RZ8JA0Q2ETL Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-11-01 RF cal date: 20170926 IMEI: 352719097932437 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... error (1 19) Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.30.4 |
01-17-2018, 05:25 | #5 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Bangladesh
Member: 1839622 Status: Offline Sonork: 100.1649155 Thanks Meter: 69 | J710f phone same problem but new file Ando: 7.0 v.. flash & unlock sim & octopus box.. Unlock Done.. or unlock sim link But new root tey Z3x box Unlock sim link..this tey http://grameenmobile1.********.com/2...ile-stock.html |
01-17-2018, 06:19 | #6 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Melbourne Aussy
Member: 192176 Status: Offline Sonork: 100.1646924 Thanks Meter: 35 | UNLOCK INSTRUCTIONS: To unlock: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' for direct unlock. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Unlock Selected model: SM-J701F Software version: 30.5 Waiting ADB device... OK Reading phone info... Model: SM-J701F Android version: 7.0 Product code: SM-J701FZKDXID Phone version: J701FXXU3AQL2 PDA version: J701FXXU3AQL2 CSC version: J701FOLE3AQL2 CSC country code: INDONESIA CSC sales code: XID HW version: MP 0.400 Phone SN: RF8J818RPJA Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-12-01 RF cal date: 20170809 IMEI: 351569095036926 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... error (1 19) Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.30.5 |
The Following 2 Users Say Thank You to Vortune_labs For This Useful Post: |
