03-30-2017, 17:04 | #1 (permalink) |
Freak Poster Join Date: Dec 2009 Location: india
Member: 1178839 Status: Offline Sonork: 100.1609495 Thanks Meter: 74 | samsung j200f unlock problem Selected model: SM-J200F Software version: 27.9 Waiting ADB device... Ok Reading phone info... Model: SM-J200F Android version: 5.1.1 Product code: SM-J200FZDDTHR Phone version: J200FXXU2API1 PDA version: J200FXXU2APJ1 CSC version: J200FOJV2APJ1 CSC country code: IRAN CSC sales code: THR HW version: MP 0.300 Phone SN: RV8J10RYKNY Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2016-10-01 RF cal date: 20170111 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Reading data... Ok Reading MODEM... error Initialization zTool... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.27.9 |
The Following User Says Thank You to sadhna_mobile For This Useful Post: |
05-28-2017, 11:14 | #3 (permalink) |
No Life Poster Join Date: Nov 2014 Location: BADARPUR ASSAM (I N D I A) Age: 34
Member: 2298142 Status: Offline Thanks Meter: 240 | first need super root. and select j200g unlock 1000000% unlock done UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Unlock Selected model: SM-J200F Software version: 28.1 Waiting ADB device... Ok Reading phone info... Model: SM-J200F Android version: 5.1.1 Product code: SM-J200FZDDKSA Phone version: J200FXXU3AQC1 PDA version: J200FXXU3AQC2 CSC version: J200FOJV3AQC1 CSC country code: KSA CSC sales code: KSA HW version: MP 0.300 Phone SN: RV8J308X2AE Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2017-03-01 RF cal date: 20170310 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Reading data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data... Ok HWID: 23 21 88 5A 37 98 76 04 2B 5E DE 62 DD C9 98 30 Calculating... Ok Unlocking... Ok Writing NV data... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28. |
06-23-2017, 16:13 | #4 (permalink) |
Insane Poster Join Date: Nov 2007 Location: india, kakinada
Member: 627678 Status: Offline Thanks Meter: 14 | Operation: Unlock Selected model: SM-J200F Software version: 28.2 waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-J200F Android version: 5.1.1 Product code: SM-J200FZWDKSA Phone version: J200FXXU3AQE1 PDA version: J200FXXU3AQE1 CSC version: J200FOJV3AQE1 CSC country code: KSA CSC sales code: KSA HW version: MP 0.300 Phone SN: RV8HB1HBJQH Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2017-05-01 RF cal date: 20161128 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Reading data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data... error (1 13.2) Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... error (0) Try downgrade modem if possible Samsung J200f new version unlock not done. Please give solution |
