06-20-2016, 08:07 | #1 (permalink) |
No Life Poster Join Date: Dec 2008 Location: GUJARAT-INDIA
Member: 926215 Status: Offline Sonork: 100.1650776 Thanks Meter: 95 | Samsung j200g and samsung s7262 no service problem PHONE IS ROOTED BACK UP EFS RESET EFS REPAIR IMEI DO ALL SERVICE BUT DOES NOT GOT RESULT ..... |
09-01-2016, 17:47 | #3 (permalink) | |
Freak Poster Join Date: Mar 2015 Location: New Delhi Age: 28
Member: 2355125 Status: Offline Thanks Meter: 52 | Bro Try To repair cert file with Z3X 100% success Quote:
here is the log BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-J200G Software version: 26.6 Waiting ADB device... OK Reading phone info... Model: SM-J200G Android version: 5.1.1 Product code: SM-J200GZDDINS Phone version: J200GDDU1AOI3 PDA version: J200GDDU1AOI3 CSC version: J200GODD1AOI3 CSC country code: India CSC sales code: INS HW version: MP 0.300 Phone S/N: RZ8H30HZ9VT Modem board: SHANNON308 RF cal date: 20160313 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 57 79 8D D0 7A 46 DE 57 01 63 4F 9C C6 5C 3E 0D Checking certificate file... OK KEY ID: 0978 Reading nv data... OK Checking NV data... OK Calculating... OK Writing nv data... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.26.6 | |
