01-30-2017, 12:07 | #6 (permalink) |
No Life Poster Join Date: May 2016
Member: 2577670 Status: Offline Thanks Meter: 883 | http://forum.gsmhosting.com/vbb/f453...e-z3x-2187078/ CLICK ON THE THANKS BUTTON IF THIS POST WAS HELPFULL |
01-31-2017, 22:14 | #7 (permalink) | |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Quote:
Code: UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. If phone ask codes after unlocking, use: PUK - 12345678 PIN - 11111111 To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-J320FN Software version: 27.7 Searching Samsung modem... detected COM101 Reading phone info... Ok Model: SM-J320ZN Version: J320ZNDOU1APH1/J320ZN2DX1APH1/J320ZNDOU1APG2/J320ZNDOU1APH1 Product code: SM-J320ZZKN2DX Phone SN: R58HA1LSP6H IMEI: 358523070414288 Unique number: CQN00F57D97B183 Unlocking... error (1) Done with Samsung Tool PRO v.27.7 | |
06-01-2017, 02:22 | #8 (permalink) |
Junior Member Join Date: Jun 2013 Location: Australia
Member: 1965736 Status: Offline Thanks Meter: 1 | i am getting the same Error with Samsung Pro V28.2 Phone is setup as DM+Modem+ADB Phone is plugged into USB Cable,and Have Tried UART Cable via the J320FN Listed on the Software Is it even possible to unlock this phone? the J320ZN Locked by Telstra? |
