03-21-2018, 13:21 | #1 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Pakistan
Member: 2478233 Status: Offline Thanks Meter: 596 | Samsung j5 prime sm-g570f/ds frp removed with just one click UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. Operation: Reset FRP Selected model: SM-G570F Software version: 31.0 Waiting ADB device... OK Reading phone info... Model: SM-G570F Android version: 7.0 Product code: SM-G570FZKDPAK Phone version: G570FXXU1BQI6 PDA version: G570FXXU1BQL2 CSC version: G570FOJV1BQL2 CSC country code: PAKISTAN CSC sales code: PAK HW version: MP 0.500 Phone SN: R28HB491RJE Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-12-01 RF cal date: 20161129 IMEI: 3552xxxxxxxxxxxx Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.31.0 |
