12-29-2015, 11:40 | #1 (permalink) |
No Life Poster Join Date: May 2012 Location: PARADISE ON EARTH(KASHMIR)
Member: 1754881 Status: Offline Sonork: 100.1644926 Thanks Meter: 146 | Samsung j500f frp lock......z3x team here is log... UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', enable 'USB debugging' in 'Settings'-'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP' to deactivate Google account activation lock. 4. Press 'Reset Reactivation Lock' to deactivate Samsung reactivation lock. Operation: Reset FRP/React/EE Selected model: SM-J500F Software version: 23.4.1 Searching Samsung USB Flash Interface... detected COM138 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... error Done with Samsung Tool PRO v.23.4.1 NOW HANDSET GIVE ME THIS ERROR WHEN I ON IT.... An error has occurred while updating the device software use the emergency recovery function in the smart switch pc software PLEASE HELP ME BLANG SIR WHAT IS THIS PROBLEM AND HOW I SOLVE IT. REGARDS.....MIRTELECOM |
02-03-2016, 16:01 | #7 (permalink) | |
No Life Poster Join Date: Mar 2015 Location: kapurthala punjab
Member: 2362867 Status: Offline Sonork: ththtuu Thanks Meter: 659 | Quote:
07-06-2016, 12:07 | #9 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1509850 Status: Offline Sonork: [email protected] Thanks Meter: 0 | j500f google acount lock sir jee hi sir j500f google lock |
06-28-2017, 15:27 | #10 (permalink) |
Insane Poster Join Date: Feb 2017 Location: Gazipur
Member: 2680150 Status: Offline Thanks Meter: 10 | UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Unlock' button for direct unlock. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Reset FRP/React/EE Selected model: SM-J500F Selected port: COM38 Silicon Labs Dual CP2105 USB to UART Bridge: Enhanced COM Port Software version: 28.2 Searching Samsung USB Flash interface... COM10 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP lock... Ok Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.2 |
