10-15-2018, 06:07 | #1 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Pakistan
Member: 2478233 Status: Offline Thanks Meter: 596 | Samsung j600f frp problem COMBINATION_FAC_FA80_J600FXXU1ARE1 now phone boots up in factory binary mode enabled oem usb debuging after that i flash with this J600FXXU1ARE2_J600FOJM1ARDL_PAK mobile stuck on boot lope so i again flashed with combination phone boots up normal not in factory binary mode but some applications says mtp application has stopped so i again flashed with combination but same now after flashing phone is not going to factory binary mode it still boot up normal phone is binary 1 J600FXXU1ARE1 need solution as soon as possible tried flashing with odin z3x but same tried flashing with J600FXXU1ARE1 odin z3x same phone boot up normal with application stopped error |
10-15-2018, 06:25 | #2 (permalink) |
Member: 2478233 Status: Offline Thanks Meter: 596 | when flashing combination phone boots up like this when flashing with this file J600FXXU1ARE2_J600FOJM1ARDL_PAK phone rebot on samsung j6 logo here is download mode pic |
10-16-2018, 04:46 | #5 (permalink) |
Member: 2478233 Status: Offline Thanks Meter: 596 | first download this combination and flash COMBINATION_FAC_FA80_J600FXXU1ARE1 phone will boot up in factory binary mode enable oem usb debuging from devolper mode and flash back stock room if boot lope select bl,ap,skip cp,and in home csc tap put this CSC_OMC_OJM_J600FOJM1ARDL_CL13500811_QB17932729_RE V00_user_low_ship.tar.md5 phone will stuck on recovery mode now flash with z3x and select ap,cp,bl,home csc now phone will boot up normal frp off oem off and you are ready to go |
The Following 4 Users Say Thank You to Arslanmayo For This Useful Post: |
09-10-2019, 11:08 | #7 (permalink) |
Banned Join Date: Dec 2018 Location: India
Member: 2885667 Status: Offline Thanks Meter: 39 | You have to install official ROM again and flash Stock firmware in case you face MTP has stoped Download Samsung Galaxy J6 2018 J600F Combination file FRP file |
