10-04-2016, 17:26 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: huanuco-peru
Member: 1168673 Status: Offline Sonork: 100.1638333 Thanks Meter: 235 | samsung j700m imie 35000000000006 no repair EFS/NV DATA operations: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write NV DATA' if you need to restore NV backup. Certificate operations: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. Operation: Write CERT Selected model: SM-J700M Software version: 26.9 Searching Samsung modem... detectado COM53 Leyendo información del teléfono ... OK Modelo: SM-J700M AP version: J700MUBU1AOG1 CSC version: J700MUUB1AOG1 CP version: J700MUBU1AOG2 Código del Producto: XXXXXXXXXXXXXX Phone SN: R28H21S7YEL Número único: C0000836152D952 Reading IMEI... OK IMEI: 000000000000000 (SIGN: NG_SIGN) Lectura de datos desde el teléfono ... OK Comprobando archivo de certificado... OK KEY ID: 0182 Writing CERT... OK Writing MSL ADDR... OK Reading IMEI... OK IMEI: 359271072094570 (SIGN: OK) Reiniciando teléfono ... OK Write CERT done Done with Samsung Tool PRO v.26.9 |
The Following User Says Thank You to m&s For This Useful Post: |
10-04-2016, 18:09 | #2 (permalink) |
Member: 1168673 Status: Offline Sonork: 100.1638333 Thanks Meter: 235 | BACKUP INSTRUCCIONES: EFS/NV DATA operations: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write NV DATA' if you need to restore NV backup. Certificate operations: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. Operation: Write CERT Selected model: SM-J700M Software version: 26.9 Searching Samsung modem... detectado COM5 Leyendo información del teléfono ... OK Modelo: SM-J700M AP version: J700MUBU1AOL1 CSC version: J700MUWA1AOL1 CP version: J700MUBU1AOL1 Código del Producto: XXXXXXXXXXXXXX Phone SN: R28H21S7YEL Número único: C0000836152D952 Reading IMEI... OK IMEI: 000000000000000 (SIGN: NG_SIGN) Lectura de datos desde el teléfono ... OK Comprobando archivo de certificado... OK KEY ID: 0182 Writing CERT... OK Writing MSL ADDR... OK Reading IMEI... error (4) Reiniciando teléfono ... OK Write CERT done Done with Samsung Tool PRO v.26.9 |
