02-21-2017, 10:58 | #1 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Lucknow
Member: 2298369 Status: Offline Thanks Meter: 440 | samsung j710f unlock sucessfull UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. Operation: Read Codes Selected model: SM-J710F Software version: 27.7 Searching Samsung modem... detected COM77 Reading phone info... OK Model: SM-J710F AP version: J710FXXU1APLM CSC version: J710FOJV1APJ1 CP version: J710FXXU1APH4 Product code: SM-J710FZWDKSA Phone SN: RF8HB2SYT7D Unique number: CAJ03C14052FBA3 Reading IMEI... OK IMEI: 357412077998058 (SIGN: OK) IMEI 2: 357413077998056 (SIGN: OK) Checking hash file... OK Reading data from phone... OK Modem board: SHANNON315 HWID: 35 07 00 00 00 00 00 00 00 00 00 00 4A 8D BB BC Reading NV data... OK Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:07) Freeze code: 95359197 NET lock: 95206029 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.27.7 |
