06-28-2017, 05:50 | #33 (permalink) |
Junior Member Join Date: Apr 2009 Age: 34
Member: 1019716 Status: Offline Thanks Meter: 3 | J710FN-DD FRP UNLOCK samsung j710fn frp lock solution | GSM FUTURE BD |
The Following User Says Thank You to gursewak For This Useful Post: |
10-30-2017, 16:24 | #36 (permalink) |
Freak Poster Join Date: Feb 2014 Location: indore
Member: 2120393 Status: Offline Thanks Meter: 238 | first check which version in ur model 7.0 or 6.0 and which month patch file ....... Just start ur mobile in recovery mode n see upper side in recovery it shows u version of mobile 7.0 or 6.0 n behind model number shows u which file in this model...... Examle ....g610fddu1aqf3.......got it AFTER THAT U SHOULD DOWNLOAD COMBINATION FILE FROM Z3X SHELL ACCORDING TO FILE VERSION N g610fddu1aqf3 PATCH VERSION after known all of the part of work ur work will be easy....... IF IS IT USEFULL JUST PRESS THANKS BUTTON |
11-03-2017, 23:51 | #37 (permalink) |
Insane Poster Join Date: Dec 2010 Location: ROUBAIX FRANCE
Member: 1468766 Status: Offline Thanks Meter: 17 | Performed by 2.6.1 Software version. Selected AP file: C:\Users\mohamed abu adam\Desktop\Samsung \COMBINATION_OXA_FA60_J710FXXU1APD2_OXA1APD2 \COMBINATION_OXA_FA60_J710FXXU1APD2_OXA1APD2 \COMBINATION_OXA_FA60_J710FXXU1APD2_OXA1APD2 _CL7564864_QB9121310_REV03_user_mid_noship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-J710F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOT section... BOOT section has been written successfully. Firmware writing successfully completed. Performed by 2.6.1 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-J710F Searching for UART interface.. COM5 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Rebooting phone in Upload Mode...OK Please connect phone to USB cable.. Searching for a phone. Please wait...OK Reading data... Checking operation...OK Searching for UART interface.. COM5 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Resetting FRP lock (1/4 attempt)..unsuccessful Searching for UART interface.. COM5 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Resetting FRP lock (2/4 attempt)..success FRP / Reactivation lock is successfully reseted! Performed by 2.6.1 Software version. |
11-19-2017, 23:06 | #38 (permalink) | |
Junior Member Join Date: Jan 2009
Member: 944199 Status: Offline Thanks Meter: 1 | Hi guys, maybe someone can help me. i have a device SM-J710FN FCC - A3LSMJ710FN SSN J710FNGSMH I try to follow the istruction on this link gsmfuturebd***/index***?threads/samsung-j710fn-frp-lock-solution.1046/ after the download of combination file i flash the boot. This is the log Operazione: Reset FRP Quote:
If i try to start the phone show the bootlogo and after it nothing if i try to flash another firmaware i get errors on recovery mode i saw this, so is the last firmaware right? J710FXXU3BQI7 how can i fix it? | |
11-20-2017, 14:25 | #39 (permalink) | |
Member: 2120393 Status: Offline Thanks Meter: 238 | Quote:
11-25-2017, 03:20 | #42 (permalink) |
Member: 2120393 Status: Offline Thanks Meter: 238 | Well dear you are trying wrong firmware it's downgrade version.... You will have to try with latest firmware of j710fn model don't worry it's not riski.... Because J710f model can take j710fn firmware..... I will try to give you link... But first you should try on sammobile firmware site for latest firmware for j710fn model..... Beat of luck Sent from my Redmi Note 3 using Tapatalk |
11-27-2017, 08:43 | #44 (permalink) | |
https://www.youtube.com/watch?v=xi3CZ3GW6pw | |
The Following User Says Thank You to mintu4200 For This Useful Post: |
