Old 06-13-2017, 05:18   #31 (permalink)
Yusuf Lawal's Avatar
Member: 1677653
Thanks Meter: 1,131
this is a very useful report
Old 06-13-2017, 19:29   #32 (permalink)
Member: 1216263
Thanks Meter: 117
Originally Posted by fretburner View Post
FRP reset done but after flashing back original firmware still FRP locked.
Same here, this is not working.
Old 06-28-2017, 05:50   #33 (permalink)
Member: 1019716
Thanks Meter: 3
J710FN-DD FRP UNLOCK
samsung j710fn frp lock solution | GSM FUTURE BD
The Following User Says Thank You to gursewak For This Useful Post:
Old 10-12-2017, 16:30   #34 (permalink)
Member: 1695806
Thanks Meter: 3
use bst very esy reset frp 100000%
Old 10-20-2017, 00:39   #35 (permalink)
Member: 1468766
Thanks Meter: 10
hello
no work flash file
Old 10-30-2017, 16:24   #36 (permalink)
mintu4200's Avatar
Member: 2120393
Thanks Meter: 127
Smile
Originally Posted by my phone59 View Post
hello
no work flash file
first check which version in ur model 7.0 or 6.0 and which month patch file .......
Just start ur mobile in recovery mode n see upper side in recovery
it shows u version of mobile 7.0 or 6.0 n behind model number shows u which file in this model......
Examle ....g610fddu1aqf3.......got it
AFTER THAT U SHOULD DOWNLOAD COMBINATION FILE FROM Z3X SHELL ACCORDING TO FILE VERSION N g610fddu1aqf3 PATCH VERSION
after known all of the part of work ur work will be easy.......
IF IS IT USEFULL JUST PRESS THANKS BUTTON
Old 11-03-2017, 23:51   #37 (permalink)
Member: 1468766
Thanks Meter: 10
Performed by 2.6.1 Software version.
Selected AP file: C:\Users\mohamed abu adam\Desktop\Samsung
\COMBINATION_OXA_FA60_J710FXXU1APD2_OXA1APD2
_CL7564864_QB9121310_REV03_user_mid_noship.tar.md5
Please put the phone into Download Mode and connect USB cable.
To put SM-J710F into Download Mode, You have to perform the
following steps:
1. Reconnect the battery.
2. Press and hold "Volume-" + "Home" + "Power ON" keys.
3. When phone turns on, press "Volume+" key.
Found phone on
Advanced mode!
Firmware write started.
Writing BOOT section...
BOOT section has been written successfully.
Firmware writing successfully completed.
Platform: Samsung Android
Selected port: COM14
Selected model: SM-J710F
Searching for UART interface.. COM5
Connect Samsung Micro UART cable(with 525K resistor), press and
hold "Vol-" + "Power" buttons for 15-20 seconds
Searching for device. Please wait...
Phone found.
Rebooting phone in Upload Mode...OK
Please connect phone to USB cable..
Searching for a phone. Please wait...OK
Reading data...
Checking operation...OK
Phone found.
Resetting FRP lock (1/4 attempt)..unsuccessful
Phone found.
Resetting FRP lock (2/4 attempt)..success
FRP / Reactivation lock is successfully reseted!
Old 11-19-2017, 22:06   #38 (permalink)
Member: 944199
Hi guys, maybe someone can help me.
i have a device SM-J710FN
FCC - A3LSMJ710FN
SSN J710FNGSMH
I try to follow the istruction on this link gsmfuturebd***/index***?threads/samsung-j710fn-frp-lock-solution.1046/
after the download of combination file i flash the boot.
This is the log
Operazione: Reset FRP
[ 18/11/2017 18:52:00 ] Selected model: SM-J710FN
[ 18/11/2017 18:52:00 ] Versione Software: 29.6
[ 18/11/2017 18:52:00 ] Aspettando ADB dispositivo... Ok
[ 18/11/2017 18:52:00 ] Lettura info telefono...
[ 18/11/2017 18:52:00 ] Modello: SM-J710F
[ 18/11/2017 18:52:00 ] Android versione: 7.0
[ 18/11/2017 18:52:00 ] Codice prodotto:
[ 18/11/2017 18:52:00 ] Versione Phone:
[ 18/11/2017 18:52:00 ] PDA versione: J710FXXU3BQI7
[ 18/11/2017 18:52:00 ] CSC versione:
[ 18/11/2017 18:52:00 ] Codice Paese CSC:
[ 18/11/2017 18:52:00 ] Codice vendita CSC:
[ 18/11/2017 18:52:00 ] HW versione:
[ 18/11/2017 18:52:00 ] Telefono SN:
[ 18/11/2017 18:52:00 ] Nome Chip: EXYNOS7870
[ 18/11/2017 18:52:00 ] Piastra modem:
[ 18/11/2017 18:52:00 ] Security patch: 2017-08-01
[ 18/11/2017 18:52:00 ] RF cal data:
[ 18/11/2017 18:52:00 ] IMEI:
[ 18/11/2017 18:52:00 ] Bypass FRP... Ok
[ 18/11/2017 18:52:00 ] For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
On download mode show model J710F and not FN
If i try to start the phone show the bootlogo and after it nothing
if i try to flash another firmaware i get errors
on recovery mode i saw this, so is the last firmaware right? J710FXXU3BQI7
how can i fix it?
Old 11-20-2017, 13:25   #39 (permalink)
mintu4200's Avatar
Member: 2120393
Thanks Meter: 127
Originally Posted by benz83 View Post
hi guys, maybe someone can help me.
I have a device sm-j710fn
fcc - a3lsmj710fn
ssn j710fngsmh
i try to follow the istruction on this link gsmfuturebd***/index***?threads/samsung-j710fn-frp-lock-solution.1046/
This is the log
operazione: Reset frp
on download mode show model j710f and not fn
if i try to start the phone show the bootlogo and after it nothing
on recovery mode i saw this, so is the last firmaware right? J710fxxu3bqi7
how can i fix it?
which firmware you use please show the firmware version name here
Old 11-20-2017, 13:44   #40 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 517
everybody please try hard .brain game
Old 11-20-2017, 21:12   #41 (permalink)
Member: 944199
Well, i try this J710FN_XXU1APG2_OXY1APG2.zip and J710F_XXU1API1_OXY1APG2.zip
Old 11-25-2017, 02:20   #42 (permalink)
mintu4200's Avatar
Member: 2120393
Thanks Meter: 127
Well dear you are trying wrong firmware it's downgrade version.... You will have to try with latest firmware of j710fn model don't worry it's not riski.... Because J710f model can take j710fn firmware..... I will try to give you link... But first you should try on sammobile firmware site for latest firmware for j710fn model..... Beat of luck
Sent from my Redmi Note 3 using Tapatalk
Old 11-25-2017, 15:24   #43 (permalink)
Member: 944199
yeah, its works, thanks, but now i need to remove the frp
however i used this : J710FXXU3BQHE_J710FOJV3BQHE_J710FXXU3BQH2_HOME.tar
Old 11-27-2017, 07:43   #44 (permalink)
mintu4200's Avatar
Member: 2120393
Thanks Meter: 127
Arrow
HERE IS YOUR LATEST FRP SOLUTION JUST PRESS THANKS BUTTON IF LIKE
https://www.youtube.com/watch?v=xi3CZ3GW6pw
The Following User Says Thank You to mintu4200 For This Useful Post:
Old 12-15-2017, 05:48   #45 (permalink)
Member: 1956642
Sonork: pradip518
Thanks Meter: 4
not work with j510fn repartition failed
Page generated in 0.60171 seconds with 7 queries
