Old 12-08-2016, 13:18   #1 (permalink)
Member: 1905377
Thanks Meter: 69
Samsung J710FN J7 2016 FRP DONE!!!
Z3X you are crazy
BYPASS SM-J710F DONE by Z3X
1. download combination, extract file
2. flash only "boot.img" like this Galaxy A3 2016 - A310F Z3X FRP Reset done but still locked?
3. Go to recowery (3 button) and do Factory reset data
4. Power ON phone
5. Connect to PC, install ADB driver and do "reset frp" in z3x
6. Enable OEM in developer option
7. Done )
[ 08.12.2016 16:00:00 ] Operation: Flash
[ 08.12.2016 16:00:00 ] Selected model: SM-J710F
[ 08.12.2016 16:00:00 ] Software version: 27.4.2
[ 08.12.2016 16:00:00 ] File analysis... Ok
[ 08.12.2016 16:00:00 ] Total file size: 0x00F42120 (15 Mb)
[ 08.12.2016 16:00:00 ] Searching USB Flash interface... COM15 detected
[ 08.12.2016 16:00:00 ] Setup connection... Ok
[ 08.12.2016 16:00:00 ] Reading PIT from phone... Ok
[ 08.12.2016 16:00:00 ] Sending boot.img... Ok
[ 08.12.2016 16:00:00 ] Flashing done (time - 00:00:03)
[ 08.12.2016 16:02:00 ] Operation: Info
[ 08.12.2016 16:02:00 ] Selected model: SM-J710F
[ 08.12.2016 16:02:00 ] Software version: 27.4.2
[ 08.12.2016 16:02:00 ] Searching Samsung modem... not found
[ 08.12.2016 16:03:00 ]
[ 08.12.2016 16:06:00 ] Operation: Reset FRP
[ 08.12.2016 16:06:00 ] Selected model: SM-J710F
[ 08.12.2016 16:06:00 ] Software version: 27.4.2
[ 08.12.2016 16:06:00 ] You must activate ADB before reset FRP Yes
[ 08.12.2016 16:06:00 ] Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes
[ 08.12.2016 16:06:00 ] Waiting ADB device... Ok
[ 08.12.2016 16:06:00 ] Reading phone info...
[ 08.12.2016 16:06:00 ] Model: SM-J710F
[ 08.12.2016 16:06:00 ] Android version: 6.0.1
[ 08.12.2016 16:06:00 ] Product code: SM-J710FZDUSER
[ 08.12.2016 16:06:00 ] Phone version: J710FXXU1APJ4
[ 08.12.2016 16:06:00 ] PDA version: J710FXXU1API6
[ 08.12.2016 16:06:00 ] CSC version: J710FOXY1API6
[ 08.12.2016 16:06:00 ] CSC country code: Russia
[ 08.12.2016 16:06:00 ] CSC sales code: SER
[ 08.12.2016 16:06:00 ] HW version: MP 0.300
[ 08.12.2016 16:06:00 ] Phone SN: RF8H63294BP
[ 08.12.2016 16:06:00 ] Chip name: EXYNOS7870
[ 08.12.2016 16:06:00 ] Modem board: SHANNON315
[ 08.12.2016 16:06:00 ] RF cal date: 20160629
[ 08.12.2016 16:06:00 ] IMEI:
[ 08.12.2016 16:06:00 ] Bypass FRP... Ok
[ 08.12.2016 16:06:00 ] For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
The Following 8 Users Say Thank You to Big_Ant For This Useful Post:
Old 12-21-2016, 17:05   #2 (permalink)
galijus's Avatar
Member: 1131244
Sonork: 100.1596724
Thanks Meter: 338
Originally Posted by Big_Ant View Post
Z3X you are crazy
4. Power ON phone
7. Done )
Very good my friend,success when others fail :
  UNLOCK INSTRUCTIONS:
    To unlock NEW security type:
    Phone must be rooted!
  If the software can't root the phone automatically,
  then you must root your device manually.
  1. Power on the phone.
  2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
     go to 'Settings'-'Developer options' and enable 'USB debugging'.
  3. Connect the phone to PC with USB cable, install drivers if needed.
  4. Select device in ADB settings.
  5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
    To unlock OLD security type:
  2. Connect the phone to PC with USB cable.
  3. Check Samsung modem in device manager, install drivers if needed.
  4. Press 'Unlock' button and select 'Unlock' for direct unlock.
    To read security codes (all security types):
  4. Press 'Read codes' button to read security codes.
Selected model: SM-J710FN
Software version: 27.5
Model: SM-J710F
Product code: SM2J710FZKNSEE
Phone version: J710FXXU2APK2
PDA version: J710FXXU2APK2
CSC version: J710FOXX2APK1
CSC country code: SEAD
CSC sales code: SEE
Phone SN: RF8H92ENLEX
RF cal date: 20160922
IMEI:
Bypass FRP... Ok
Done with Samsung Tool PRO v.27.5
Old 03-20-2017, 19:06   #3 (permalink)
Member: 2367111
Thanks Meter: 3
100% Success ! Thank you a lot !
Old 03-27-2017, 10:02   #4 (permalink)
Member: 83104
Thanks Meter: 9
File analysis... Ok
Total file size: 0x4D516360 (1237 Mb)
Searching USB Flash interface... COM27 detected
Sending sboot.bin... Ok
Sending param.bin... error timeout
Done with Samsung Tool PRO v.27.9
dont work for me
sw rev. check fail device: 2, binary: 1
Old 04-01-2017, 23:40   #5 (permalink)
Member: 1478562
Thanks Meter: 34
Z3X you are crazy
4. Power ON phone
7. Done )
[ 08.12.2016 16
thank you mate its perfectly working....
good job brother.....
Old 04-12-2017, 12:34   #6 (permalink)
Member: 652541
Thanks Meter: 45
100000000000...................... working
Old 04-16-2017, 07:36   #7 (permalink)
Member: 718338
Sonork: 100.1623688
Thanks Meter: 39
says done but not unlock phone
Old 04-16-2017, 07:45   #8 (permalink)
Member: 718338
Sonork: 100.1623688
Thanks Meter: 39
[ 4/15/2017 10:37:00 AM ]
[ 4/15/2017 10:47:00 AM ] Operation: Reset FRP
[ 4/15/2017 10:47:00 AM ] Selected model: SM-J710F
[ 4/15/2017 10:47:00 AM ] Software version: 28.1
[ 4/15/2017 10:47:00 AM ] Waiting ADB device... Ok
[ 4/15/2017 10:47:00 AM ] Reading phone info...
[ 4/15/2017 10:47:00 AM ] Model: SM-J710F
[ 4/15/2017 10:47:00 AM ] Android version: 6.0.1
[ 4/15/2017 10:47:00 AM ] Product code: SM-J710FZDUSER
[ 4/15/2017 10:47:00 AM ] Phone version: J710FXXU2AQA4
[ 4/15/2017 10:47:00 AM ] PDA version: J710FXXU2AQA8
[ 4/15/2017 10:47:00 AM ] CSC version: J710FOXY2AQA2
[ 4/15/2017 10:47:00 AM ] CSC country code: Russia
[ 4/15/2017 10:47:00 AM ] CSC sales code: SER
[ 4/15/2017 10:47:00 AM ] HW version: MP 0.300
[ 4/15/2017 10:47:00 AM ] Phone SN: RZ8H71C2RMF
[ 4/15/2017 10:47:00 AM ] Chip name: EXYNOS7870
[ 4/15/2017 10:47:00 AM ] Modem board: SHANNON315
[ 4/15/2017 10:47:00 AM ] Security patch: 2017-01-01
[ 4/15/2017 10:47:00 AM ] RF cal date: 20160721
[ 4/15/2017 10:47:00 AM ] IMEI:
[ 4/15/2017 10:47:00 AM ] Bypass FRP... Ok
[ 4/15/2017 10:47:00 AM ] For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Old 04-16-2017, 07:59   #9 (permalink)
Member: 1993526
Sonork: 100.1608505
Thanks Meter: 10
I also tried it and it works...
Old 08-15-2017, 22:24   #10 (permalink)
Member: 1641656
tanx brother it works tanx alotf
Old 08-23-2017, 00:44   #11 (permalink)
Member: 2098883
how it is work,set is on frp pls help
Page generated in 0.37921 seconds with 7 queries
