08-30-2016, 13:31 | #1 (permalink) | |
Moderator Join Date: Apr 2011 Location: B.A.N.G.L.A.D.E.S.H Age: 34
Member: 1566464 Status: Offline Sonork: 100.1611207 Thanks Meter: 929 | samsung j710gn unlock done with z3x 6.1 ver no risk im tested enjoy Quote:
The Following 2 Users Say Thank You to sayed tarik For This Useful Post: |
01-02-2017, 10:47 | #2 (permalink) |
Freak Poster Join Date: Jul 2014 Location: bangladesh
Member: 2227733 Status: Offline Thanks Meter: 69 | UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Unlock Selected model: SM-J710GN Software version: 26.9 Searching Samsung modem... detected COM4 Reading phone info... OK Model: SM-J710GN AP version: J710GNDXU1API5 CSC version: J710GNOLB1API2 CP version: J710GNDXU1API1 Product code: SM-J710GZKUXME Phone SN: RF8HB3APF7K Unique number: CAJ03ECDD5E63A3 Reading IMEI... OK IMEI: 3584470764xxxx (SIGN: OK) IMEI 2: 3584xxxxxxx (SIGN: OK) Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.9 |
04-29-2017, 08:33 | #5 (permalink) |
Freak Poster Join Date: Aug 2009 Location: kottawa,sri lanka
Member: 1095235 Status: Offline Thanks Meter: 36 | unlock with out root To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. Operation: Unlock Selected model: SM-J710GN Software version: 28.0 Searching Samsung modem... detected COM95 Reading phone info... Ok Model: SM-J710GN AP version: J710GNDXU2APL1 CSC version: J710GNOLB2APL1 CP version: J710GNDXU2APL1 Product code: SM-J710GZDUXME Phone SN: RF8J217YSQR Unique number: C0000C3245502B3 Reading IMEI... Ok IMEI: 358447077958180 (SIGN: OK) IMEI 2: 358448077958188 (SIGN: OK) Reading data from phone... Ok Unlocking... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.0 |
05-22-2017, 10:12 | #6 (permalink) |
Junior Member Join Date: May 2013 Location: iran Age: 34
Member: 1949368 Status: Offline Sonork: 100.1656685 Thanks Meter: 15 | Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-J710GN Android version: 6.0.1 Product code: SM-J710GZKUXSG Phone version: J710GNDXU1API1 PDA version: J710GNDXU1API5 CSC version: J710FOJV1APE1 CSC country code: UAE CSC sales code: XSG HW version: MP 0.400 Phone SN: RF8HB3LBR5M Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2016-09-01 RF cal date: 20161128 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Reading data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data... Ok HWID: 37 04 00 00 00 00 00 00 00 00 00 00 A2 C4 C6 48 Calculating... Ok Unlocking... Ok Writing NV data... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.2 |
05-24-2017, 15:46 | #7 (permalink) |
Junior Member Join Date: Jun 2015 Location: Dubai
Member: 2405406 Status: Offline Sonork: mrarhan Thanks Meter: 2 | UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: SM-J710GN Software version: 26.6 Searching Samsung modem... detected COM1519 Reading phone info... OK Model: SM-J710GN AP Version: J710GNDXU2AQB2 CSC Version: J710GNOLB2AQC1 CP Version: J710GNDXU2AQC1 Product code: SM-J710GZWUXME Phone S/N: RF8J5143EYN Unique number: CAJ03BB3B65BA34 Reading IMEI... OK IMEI: 358447078479236 (SIGN: OK) IMEI2: 358448078479234 (SIGN: OK) Checking hash file... OK Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.26.6 some one have any solution for error, read code also not done by z3x ... plz help.... |
07-16-2017, 10:48 | #9 (permalink) |
Insane Poster Join Date: Feb 2017 Location: Gazipur
Member: 2680150 Status: Offline Thanks Meter: 10 | UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. Operation: Unlock Selected model: SM-J710GN Software version: 28.2 Searching Samsung modem... detected COM179 Reading phone info... OK Model: SM-J710GN AP version: J710GNZTU2APL1 CSC version: J320FOJV0API2 CP version: J710GNZTU2APL1 Product code: SM-J710GZDUXSG Phone SN: RF8J11TF6SA Unique number: C0000D845CF55A3 Reading IMEI... OK IMEI: 358447077478635 (SIGN: OK) IMEI 2: 358448077478633 (SIGN: OK) Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.28.2 |
