08-01-2018, 18:37 | #1 (permalink) |
No Life Poster Join Date: Sep 2010
Member: 1388609 Status: Offline Sonork: atou Thanks Meter: 156 | samsung j730f emergency call only Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. Operation: Patch Certificate Selected model: SM-J730F Software version: 33.4 Waiting ADB device... OK Reading phone info... Model: SM-J730F Android version: 7.0 PDA version: J730FXWU2ARA3 CSC version: J730FYDD2ARA3 Phone version: J730FXXU2ARA3 Product code: SM-J730FZKDINS CSC country code: India CSC sales code: INS Phone SN: RF8J72A0R7K IMEI: 358754545466559 HW version: MP 0.400 RF cal date: 20170721 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2018-01-01 Boot Warranty bit: 0 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.33.4s patch done but same problem |
