Old 02-06-2010, 14:16   #1 (permalink)
Member: 954948
Samsung Jet s8000 Problems after flash ??
Hi
I flashed a jet with the patched firmware so i could unlock it, but now when it boots up the phone will turn on for approx 20 seconds and go to the home screen then will turn off and wont turn back on untill you remove and replace the battery ?
Tried to reflash again but Z3x doesnt detect the phone ???
The Following User Says Thank You to gfxunlock For This Useful Post:
Old 02-06-2010, 15:23   #2 (permalink)
Member: 288521
Thanks Meter: 646
patch fw is not stable fw
after unlocking must again flash with other fw
can u charge battery and try put into flash mode and then connect to box
please show log or screenshot
The Following User Says Thank You to zubairhussain For This Useful Post:
Old 02-06-2010, 15:38   #3 (permalink)
Crazy Poster
Member: 967943
Thanks Meter: 3
hello brother.this sort of problem happen to me aswell before.the patch file you use to unlock the phone..u should find the same version with out unlock patch.so simply
1:flash the phone with patched firmware
2:unlock it
3:flash again with normal version of patch file..
hope so it works
The Following User Says Thank You to zain.ali For This Useful Post:
Old 02-06-2010, 16:03   #4 (permalink)
Member: 954948
thanks that sorted it
Old 02-06-2010, 16:31   #5 (permalink)
Member: 836870
Sonork: sasa
Thanks Meter: 2
where can find driver for this model ?`?
Old 02-06-2010, 17:15   #6 (permalink)
Member: 288521
Thanks Meter: 646
drivers are located in z3x folder.. samsung qcomm drivers
Old 02-06-2010, 22:25   #7 (permalink)
Member: 172567
Thanks Meter: 55
got a problem sometimes to recognize usb port, I'd solved it opening downloder v5.60. after that, z3x recognize port all the times.
Z3x team, got a brasilian flash file for this model, for Downloader. Any chance to convert it to z3x format, to avoid to use other tool?
And I still need I6220 flash file, killed with imei change procedure
Thanks in advance
Old 02-08-2010, 12:22   #8 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 173,762
Thanks in advance
Flash file on support for I6220. just reflash
imei procedure wil be fixed as soon as we got this phone in hands
Old 12-24-2010, 11:27   #9 (permalink)
Member: 1476126
Angry soloution!
Hi
try flashing using different firmware, there's recently been an update for jet, http://www.gsmarena.com/major_samsun...re_update_now_ available-news-1274.php this should help. only thing i've found is I'm having trouble updating camera firmware. camera works like a dream still.
Install this software first, it contains the drivers for your phone.
Multiloader 5.56
New firmware
覧覧覧覧蘭Now you are ready to begin覧覧覧覧覧蘭
1. Make sure Samsung PC Studio is installed and communicates with your phone. And unpack the firmware in a folder you can easily find it.
2. Remove the Sim and MicroSD from your phone and replace the battery.
3. MAKE SURE THE PHONE IS OFF AND NOT CONNECTED TO THE COMPUTER.
4. Pixon and JET users : Hold down the 天olume - button on the left or right side differs, and the 鼎amera button on the right, then press the 撤ower button = all three buttons need to be pressed together. Your phone should start up into a red\blue on black bootloader screen.)
5. Now run MultiLoader v5.56
6.Plug the phone up to the computer.
1. Select the radio button Example: FOR JET LSI6410
2. Select Boot Change
3. Full Download
4. Master rom
5. Then click Boot, and select the boot files from the unpacked firmware folder.
6. Select Amss
**NOTE** You must also select 鄭PPS if you are flashing a 笛ET **NOTE**
7. Rsrc1
8. Rsrc2(Low) Do not use (Mid).r2c. On the JET may there may only be one option (Warning! phone may not restart if you select mid)
9. Select the Factory FS file.
***FOTA and ETC fields are left blank.****
10. Click the Port Search button, it will find your phone and show the com port is ready.
11. Click the download button and be patient, this will only take a few minutes to complete.
12. When it痴 finished, it will show 登k all files complete.
13. Unplug the phone from the USB cable, reinstall the sim and SD card.
14. insert battery. turn on, should start to load then go to a light blue screen.
15. once alls turnt on and runnin normal speed (nothing still loading upo i.e contacts mesage's etc) hit keypad type in *#1234# and theres is your new version..(sw ver)
s8000xeII2
(csc ver)
s8000xeII2
Samsung s5230 Network problem after flash killex 2G Latest Models 11 01-29-2011 13:56
Samsung Jet S8000 generic flash file(s)? Patrick Z3X-Team Products 0 10-13-2009 10:50
Samsung JET S8000 GSM-Telecom NSPRO 9 09-14-2009 05:22
Samsung Z-560 Problem After Flashing anchit NSPRO 1 08-02-2007 21:36
Page generated in 0.37131 seconds with 8 queries
