05-08-2013, 09:10 | #1 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | samsung M8800 UNLOCKING DON BY Z3X Code: Selected model: M8800 Selected port: COM8 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... not found Checking phone on COM8 Reading phone info... Model: GT-M8800 Country code: ¿µ±¹ Cal date: 2008-11-11 Factory SW: M8800BVHK2 Unique number: 70820000517855 Memory phone: KAV00500FM(M8800) Reading IMEI... OK IMEI: 356325023774483 Phone S/N: R8XS135581 Build: M6281A-KLRZ-4.0.96152S Done with Samsung Tool v.14.3 Selected model: M8800 Selected port: COM8 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... OK Model: GT-M8800 Country code: ¿µ±¹ Cal date: 2008-11-11 Factory SW: M8800BVHK2 Unique number: 70820000517855 Memory phone: KAV00500FM(M8800) Phone S/N: R8XS135581 Reading IMEI... OK IMEI: 356325023774483 Build: M6281A-KLRZ-4.0.96152S Reading sysinfo... OK Calculating... OK Writing sysinfo... OK Reseting... Unlock done Done with Samsung Tool v.14.3 Selected model: M8800 Selected port: COM8 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... OK Model: GT-M8800 Country code: ¿µ±¹ Cal date: 2008-11-11 Factory SW: M8800BVHK2 Unique number: 70820000517855 Memory phone: KAV00500FM(M8800) Phone S/N: R8XS135581 Reading IMEI... OK IMEI: 356325023774483 Build: M6281A-KLRZ-4.0.96152S Reading sysinfo... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:37) Freeze code: 46852614 NET lock: #7465625*638*19491605# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung Tool v.14.3 |
The Following 2 Users Say Thank You to Tanha0321 For This Useful Post: |
05-24-2013, 06:07 | #3 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 45
Member: 351924 Status: Offline Thanks Meter: 12,467 | not cuz unlock code calculate based imei number each phone used different imei |
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post: |
10-18-2014, 14:33 | #4 (permalink) |
Insane Poster Join Date: May 2011
Member: 1567028 Status: Offline Thanks Meter: 5 | Hi, I need some info on this, as I am quite new to this. I am trying to unlock samsung M8800. I connect it to UART cable and first click on "read info" That is fine and done without problems: Selected model: M8800 Selected port: COM124 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... not found Checking phone on COM124 Reading phone info... Model: GT-M8800 Country code: Çë°¡¸® Cal date: 2008-12-24 Factory SW: M8800BOHK3 Unique number: 72000000488121 Memory phone: KAV00500FM(M8800) Reading IMEI... OK IMEI: 356325024908767 Phone S/N: R1WS286095 Build: M6281A-KLRZ-4.0.96152S Done with Samsung Tool v.17.0 The problem appears when I try to unlock it, so I click on unlock and this is what it says: Selected model: M8800 Selected port: COM124 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... OK Model: GT-M8800 Country code: Çë°¡¸® Cal date: 2008-12-24 Factory SW: M8800BOHK3 Unique number: 72000000488121 Memory phone: KAV00500FM(M8800) Phone S/N: R1WS286095 Reading IMEI... OK IMEI: 356325024908767 Build: M6281A-KLRZ-4.0.96152S Reading sysinfo... error access denied Done with Samsung Tool v.17.0 From what I see some problem is as: error access denied. Please help me why is this stupid error here? what should I do in order to unlock? I am new to this and paid a lot for a box, but I did not unlock any phone yet! |
10-20-2014, 18:26 | #6 (permalink) | |
Member: 1567028 Status: Offline Thanks Meter: 5 | Quote:
These are the steps that I have done in order to solve the problem, but still it does not work: Software updated, Kies Updated Reading codes does not work, with the same error: "Reading sysinfo... error access denied" When I check "new security" option it says: Selected model: M8800 Selected port: COM124 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... not found Done with Samsung Tool v.18.2 Also I tried this trick: Type *#197328640# -> common -> usb config -> Samsung USB Nothing works so far | |
