Old 02-07-2013, 02:48   #1 (permalink)
n2roy's Avatar
Member: 1175794
Thanks Meter: 169
Samsung n7000 galaxy note imei change. 10000%
It is very hard to change IMEI number of SAMSUNG N7000 GALAXY NOTE..
But I found a solution to change or repair IMEI number of SAMSUNG N7000 GALAXY NOTE..
**** NOTE CHANGING
"IMEI" IS ILLEGAL .. AND THIS IS FOR EDUCATION AND TRAINING PURPOSE ONLY ******
We need
1) samsung tool 12.2 2) samsung tool 13.7 or higher version 4)SAMSUNG USB MODEM DRIVER 3) N7000 android 2.3.6 firmware 4) A valid IMEI
1. First we have to Flash it with Android 2.3.6 firmware.
here is the list of SAMSUNG N7000 GALAXY NOTE 2.3.6 firmwares.
Android Solution: Samsung Galaxy Note GT-N7000 All Original Europe Stock ROMs Firmware Packaged list
download any unlocked version.(i mean download without telephone company's customized or locked firmware.. like )
for example I have downloaded GT-N7000_ATO_N7000XXKKA_N7000OXXKK5 this version. if causes problem during downloading from the website , then you can download it from z3x support area. (SHELL)
2. now unzip it.
you will find a file name like "N7000XXKKA_N7000OXXKK5_N7000XXKK5_HOME.tar.md 5"
3.open samsung tool 13.7
4. SELECT N7000XXKKA_N7000OXXKK5_N7000XXKK5_HOME.tar.md5 file as PDA file .
5. NOW SWITCH OFF THE PHONE.. INSERT FULLY CHARGED BATTERY. HOLD "VOLUME DOWN" AND "HOME" KEY AND INSERT USB CABLE.
6. SELECT PORT ON SAMSUNG TOOL 13.7 ,NOW CLICK ON FLASH BUTTON.
7. AFTER FLASH
Disconnect USB cable from phone.
Go to Menu->Settings->Applications->Development.
Turn on "USB Debugging" option.
When message is appear press "Yes".
Go to dial window.
Enter "*#7284#" number.
Set "USB" radio button to "PDA" value.
Close window.
Go to dial window.
Enter "*#9090#" number.
Set "Diag config" to "USB" value.
Restart phone.
8. Now open Samsung Tool 12.2 . connect Usb to phone. Press "Read Info" in Samsung Tool 12.2.
9. press "unlock" and wait for root . it may be take 10 or 15 minute..
10. Now tick on Repair Efs and click on "Repair" button.
11. there type a valid Imei and press ok.. it may be take time and phone will restart 2 or three times..
If all thing goes well then you will get this kindda MGS...
HURRAY !!!!!!!!!!!!
The Following 3 Users Say Thank You to n2roy For This Useful Post:
Old 02-07-2013, 03:19   #2 (permalink)
Registered User
Member: 972420
Sonork: manole
Thanks Meter: 134
wow nice idea sir and tricks for newbie.........................
Old 02-07-2013, 19:28   #3 (permalink)
n2roy's Avatar
Member: 1175794
Thanks Meter: 169
After changing imei you can root it too latest android version...
Old 02-08-2013, 15:57   #4 (permalink)
Member: 233260
when you use the code * # 9090 # * the message right-rad-key: back. use the menu key-solving!
Old 02-08-2013, 23:04   #5 (permalink)
n2roy's Avatar
Member: 1175794
Thanks Meter: 169
you need to hard reset first... by holding "home" + "volume up" and power key.. the "factory reset"
Old 02-09-2013, 13:13   #6 (permalink)
Member: 263005
Thanks Meter: 92
rar pass of this file pls GT-N7000_ATO_N7000XXKKA_N7000OXXKK5
Old 02-11-2013, 10:48   #7 (permalink)
Member: 263005
Thanks Meter: 92
k
i did imei via 2.2 with andrd2.3.6 then i want to update 4.1.2 jellybean how plssss?
Old 02-11-2013, 11:12   #8 (permalink)
n2roy's Avatar
Member: 1175794
Thanks Meter: 169
here is your password-
Old 02-14-2013, 17:41   #9 (permalink)
xina's Avatar
Member: 441775
Thanks Meter: 12
hello I followed your steps but in flash gives me this error.
Exception: Access violation at address 004032B5 in module 'SamsungTool.exe'. Read of address 00000000
Done with Samsung Tool v.13.9
tried with software 13.7
Old 03-20-2013, 15:18   #10 (permalink)
n2roy's Avatar
Member: 1175794
Thanks Meter: 169
Have you tryed with 12.2 versin, first check then reply.
The Following User Says Thank You to n2roy For This Useful Post:
Old 04-19-2013, 06:56   #11 (permalink)
Member: 1919463
What all is needed do I need a box or can I just run software from my pc? Do you think this will work with the t889? If so it possible to upgrade to new rom afterwards?
Old 04-19-2013, 07:27   #12 (permalink)
n2roy's Avatar
Member: 1175794
Thanks Meter: 169
any samsung phone Imei change is possible not like Nokia phones. so if you have Z3x box or any other box then search the forum, i will find ur answer.
Old 04-27-2013, 21:43   #13 (permalink)
Member: 1921828
Wich box i can take for this? Thank you
Old 04-28-2013, 00:35   #14 (permalink)
nsns285's Avatar
Member: 80869
Sonork: 100.1638021
Thanks Meter: 75
99% from phone what have imei problem and i talk abut soft problem box cant Repair imei
just 1 from 100...
Old 04-28-2013, 02:37   #15 (permalink)
nsns285's Avatar
Member: 80869
Sonork: 100.1638021
Thanks Meter: 75
Samsung is to bad phone.... cues off this problems. riff box do some job for this problem
but we have mush problem what come hardware problem imei.....
anyway thanks z3 team also do mush job
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.35290 seconds with 8 queries
