04-25-2015, 21:59 | #1 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Samsung N7100 Not Registered To Network I Got N7100 With Factory Mode + Security Area Damage But Baseband Ok After Repair Factory Mode & Repair Security Emergency Only...I Try Unlock Repair Network...Write EFS Then Repair Security All Failed Showing Network Bars But On Operator Name Emergency...Whell Call Not Registered To Network...When I Search manually Its Show Operators Name... Then I Write Cert. All Working Fine...Then I Re Write Original No. Printed On Back Sticker Same Issue (Network)...Then Someone Told Me Issue With Imei Then i Rewrite Cert. Then Use Repair Option For Rewrite No. In Cert. After This Again Same Issue Network... It Means No Issue With No. Is QCN Write Possible With This Model?? If Yes Provide Me QCN File... I Want Original IMEI As IMEI Changing Is Crime In My Country & I Don't Do Such Type Of Work... |
04-26-2015, 08:08 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
sw - try repair imei to wanted and then do patch cert using last version. if problem remain, you can try write efs from other phone. if same possible hardware problem with TX/RX. | |
The Following 2 Users Say Thank You to blang For This Useful Post: |
05-03-2015, 00:55 | #3 (permalink) |
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Oh Yes I Forget This Is Exynos Based Phones Repair Boot Via SD Most Of Came With This Chip.... Brother Have U Complete Read My Post No Hardware Issue......Brother Can U Give Me Your Yahoo ID Pm Me..If Possible.... |
07-08-2015, 19:53 | #5 (permalink) |
Freak Poster Join Date: May 2009
Member: 1029079 Status: Offline Thanks Meter: 61 | yes done REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Fill values what you need to repair. 5. Press 'Repair' button. 6. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 7. Press 'Disable Factory Mode' or 'Patch Certificate' if needed. Operation: Patch Certificate Selected model: GT-N7100 Software version: 20.5 Waiting ADB device... OK Reading phone info... Model: GT-N7100 Android version: 4.4.2 Product code: Not Active Phone version: N7100XXUFND3 PDA version: N7100XXUFNE1 CSC version: N7100OXEFNE1 CSC country code: Russia CSC sales code: SER HW version: Unknown Phone S/N: Modem board: XMM6262 RF cal date: Unknown IMEI: 3526########### Checking Super user right... true Reading modem... OK Patching modem... OK Writing modem... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool v.20.5 |
The Following User Says Thank You to slim_j For This Useful Post: |
12-29-2015, 14:17 | #8 (permalink) | |
Junior Member Join Date: Jan 2015 Location: Gamping, Jogjakarta, Indonesia
Member: 2328779 Status: Offline Thanks Meter: 1 | help... need cert for n7100 Quote:
help needy cert file sir | |
The Following User Says Thank You to bajoe_ For This Useful Post: |
