11-11-2014, 16:59 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Cameroon Age: 52
Member: 163755 Status: Offline Thanks Meter: 126 | Samsung N7105 Unfortunately, samsung keyboard has stopped |
11-12-2014, 10:49 | #5 (permalink) | |
Member: 163755 Status: Offline Thanks Meter: 126 | Quote:
Selected model: N7105 Selected port: COM2 USB Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x4D19F9D0 Searching USB Flash Interface... detected COM55 Setup connection... OK Reading PIT from phone... OK Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Pit\N7105_12-11-2014_10-47-41.pit Sending sboot.bin... Error Done with Samsung Tool v.18.3 Done with Samsung Tool v.18.3 Last edited by djouaka; 11-12-2014 at 10:54. | |
11-12-2014, 11:03 | #6 (permalink) |
No Life Poster Join Date: Mar 2013 Location: NewYork Age: 32
Member: 1900437 Status: Offline Thanks Meter: 113 | You can also try clearing the cache and the data stored by the KeyBoard application by heading out over the Settings>application manager, and still if that doesn't helps you out also try installing some other third party apps like SwiftKeyboard to see if the problem is with the ROM itself or .... ! And if that still doesn't helps you out then you can move forward with the flashing other ROM out ! |
11-12-2014, 12:01 | #7 (permalink) | |
