09-14-2014, 02:34 | #17 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Ohhh. Thne u can buy cert file. Fine on google who sell this cert file. |
The Following User Says Thank You to razib143 For This Useful Post: |
10-10-2014, 19:06 | #19 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Ghana-Accra
Member: 311615 Status: Offline Sonork: 100.1591575 Thanks Meter: 72 | It works like a charm Selected model: SM-N9005 Selected port: COM187 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SM-N9005 Android version: 4.4.2 Product code: Not Active Phone version: N9005XXUGNG1 PDA version: N9005XXUGNG1 CSC version: N9005O2UGNG1 IMEI: 357507050099970 Phone S/N: RV1D956TFKR Checking Super user right... true Backuping MMCBLK... OK Checking phone at COM187 Detected ID: 00000FF3 (MSM8974) SW Version: M8974A-AAAANAZM-1.0.180102A Reading ESN... OK Backuping RFNV... OK Backuping Feature Mask... OK Backuping NV Item... OK Backuping NV Item SIM1... OK Backuping NV Item SIM2... OK Backuping Provisioning Item Files... OK Writing data to phone... OK Rebooting phone... OK Waiting phone... OK Reading QCN file... OK Checking phone at COM187 Detected ID: 00000FF3 (MSM8974) SW Version: M8974A-AAAANAZM-1.0.180102A Checking paths... OK Restoring EFS Backup... OK Restoring NV Items... OK Restoring NV Item SIM1... OK Restoring NV Item SIM2... OK Restoring Provisioning Item Files... OK Done with Samsung Tool v.18.1 Selected model: SM-N9005 Selected port: COM187 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Checking certificate file... OK Searching ADB device... OK Reading phone info... Model: SM-N9005 Android version: 4.4.2 Product code: Not Active Phone version: N9005XXUGNG1 PDA version: N9005XXUGNG1 CSC version: N9005O2UGNG1 IMEI: 357507050099970 Phone S/N: RV1D956TFKR Checking Super user right... true Bypass MSL... OK Checking for compatible phone and cert... OK Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool v.18.1 Done with Samsung Tool v.18.1 |
12-09-2014, 06:46 | #20 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2307036 Status: Offline Thanks Meter: 0 | i am getting this error while wiping efs here is the log Selected model: SM-N9005 Selected port: COM2 Communications Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SM-N9005 Android version: 4.4.2 Product code: SM-N9005ZKEXSI Phone version: N9005XXUGNG1 PDA version: N9005XXUGNJ2 CSC version: N9005OJVGNH2 IMEI: 351542069138861 Phone S/N: R38F30CG0JN Checking Super user right... true Backuping MMCBLK... OK Checking phone at COM2 No answer from phone Done with Samsung Tool v.18.3 Done with Samsung Tool v.18.3 any solution ??? also try *#0808# Dm+modem+adb |
01-24-2015, 16:00 | #21 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | Selected model: SM-N9005 Selected port: COM89 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Checking certificate file... OK Searching ADB device... OK Reading phone info... Model: SM-N9005 Android version: 4.3 Product code: Not Active Phone version: N9005XXUDMJ7 PDA version: N9005XXUDMJ7 CSC version: N9005OJVDMJ4 IMEI: Unknown Phone S/N: 00000000000 Checking Super user right... true Bypass MSL... OK Checking for compatible phone and cert... OK Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool v.18.7 Done with Samsung Tool v.18.7 |
02-19-2015, 03:00 | #24 (permalink) |
Junior Member Join Date: Feb 2006
Member: 234963 Status: Offline Thanks Meter: 0 | N9005 Not register on network -- Solved -- If you still can see the IMEI and are getting Not registered on network, the solution I had is using Z3X Samsung Tool v18.9. Assuming you wiped EFS using Z3X Samsung Tool v18.9 to unlock the phone and get Not registered on network afterwards. The solution is: -Open Z3X Samsung Tool v18.9 -Put your n9005 in download mode -On PDA choose from SamsungTool Backup folder a file named like this: SM-N9005_BACKUP_x dot tar <------- this are the original EFS from NVRAM -Click on flash and wait the phone start normally. It should work. |
06-29-2015, 13:10 | #26 (permalink) |
Major Poster Join Date: Sep 2014 Location: india
Member: 2257209 Status: Offline Thanks Meter: 15 | Checking certificate file... OK KEY ID: 0813 Waiting ADB device... OK Reading phone info... Model: SM-N9005 Android version: 4.4.2 Product code: Phone version: PDA version: N9005XXUENA6 CSC version: N9005OXXENA5 CSC country code: Poland CSC sales code: XEO HW version: Phone S/N: Modem board: RF cal date: IMEI: Initialization AT RIL... error Done with Samsung Tool v.20.5 |
07-05-2016, 02:28 | #29 (permalink) |
Junior Member Join Date: Jul 2016 Location: Austria
Member: 2594583 Status: Offline Thanks Meter: 0 | I have samsung note 3 n9005, well i am facing problem that my phone is not working 3g or 4g its only work on 2g , i am using vectone service i have even tried 3 mobile services also but problem remain same. I don't have much knowledge about the thing you guys are talking about, i would be very thankfull if you guys will help me out |
