12-19-2015, 10:02 | #2 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Pakistan & Bahrain Age: 37
Member: 617073 Status: Offline Sonork: 100.1611349 Thanks Meter: 316 | after write nv data security demage OK but no problem is Checking certificate file... OK KEY ID: 0065 Waiting ADB device... OK Reading phone info... Model: SM-N910C Android version: 5.0.1 Product code: Phone version: PDA version: N910CXXU1BOC5 CSC version: N910COJV1BOC2 CSC country code: Egypt CSC sales code: EGY HW version: Phone S/N: Modem board: RF cal date: IMEI: Checking Super user right... true Reading nv data... OK Analisis NV data... OK Writing nv data... OK Rebooting phone... OK Waiting ADB device... OK Reading phone info... Model: SM-N910C Android version: 5.0.1 Product code: Phone version: PDA version: N910CXXU1BOC5 CSC version: N910COJV1BOC2 CSC country code: Egypt CSC sales code: EGY HW version: Phone S/N: Modem board: RF cal date: IMEI: Initialization AT RIL... error Done with Samsung Tool PRO v.23.7 |
12-19-2015, 10:05 | #3 (permalink) |
Product Supporter Join Date: Mar 2008 Location: Thailand Age: 46
Member: 716581 Status: Offline Thanks Meter: 767 | z3x have problem in this model. i have same problem too. [ 18/12/2015 18:33:00 ] Operation: Write CERT [ 18/12/2015 18:33:00 ] Selected model: SM-N910C [ 18/12/2015 18:33:00 ] Software version: 23.7 [ 18/12/2015 18:33:00 ] [ 18/12/2015 18:33:00 ] Checking certificate file... OK [ 18/12/2015 18:33:00 ] KEY ID: 0065 [ 18/12/2015 18:33:00 ] Waiting ADB device... OK [ 18/12/2015 18:33:00 ] Reading phone info... [ 18/12/2015 18:33:00 ] Model: SM-N910C [ 18/12/2015 18:33:00 ] Android version: 5.1.1 [ 18/12/2015 18:33:00 ] Product code: [ 18/12/2015 18:33:00 ] Phone version: N910CXXU1COJ5 [ 18/12/2015 18:33:00 ] PDA version: N910CXXU2COJ5 [ 18/12/2015 18:33:00 ] CSC version: N910COLB2COJ5 [ 18/12/2015 18:33:00 ] CSC country code: THAILAND [ 18/12/2015 18:33:00 ] CSC sales code: THL [ 18/12/2015 18:33:00 ] HW version: [ 18/12/2015 18:33:00 ] Phone S/N: [ 18/12/2015 18:33:00 ] Modem board: DB7450R [ 18/12/2015 18:33:00 ] RF cal date: 1234.56.78 [ 18/12/2015 18:33:00 ] IMEI: [ 18/12/2015 18:33:00 ] Checking Super user right... true [ 18/12/2015 18:33:00 ] Reading nv data... OK [ 18/12/2015 18:33:00 ] Analisis NV data... error [ 18/12/2015 18:33:00 ] Security damaged [ 18/12/2015 18:33:00 ] [ 18/12/2015 18:33:00 ] Operation: Write NV DATA [ 18/12/2015 18:33:00 ] Selected model: SM-N910C [ 18/12/2015 18:33:00 ] Software version: 23.7 [ 18/12/2015 18:33:00 ] [ 18/12/2015 18:33:00 ] Waiting ADB device... OK [ 18/12/2015 18:33:00 ] Reading phone info... [ 18/12/2015 18:33:00 ] Model: SM-N910C [ 18/12/2015 18:33:00 ] Android version: 5.1.1 [ 18/12/2015 18:33:00 ] Product code: [ 18/12/2015 18:33:00 ] Phone version: N910CXXU1COJ5 [ 18/12/2015 18:33:00 ] PDA version: N910CXXU2COJ5 [ 18/12/2015 18:33:00 ] CSC version: N910COLB2COJ5 [ 18/12/2015 18:33:00 ] CSC country code: THAILAND [ 18/12/2015 18:33:00 ] CSC sales code: THL [ 18/12/2015 18:33:00 ] HW version: [ 18/12/2015 18:33:00 ] Phone S/N: [ 18/12/2015 18:33:00 ] Modem board: DB7450R [ 18/12/2015 18:33:00 ] RF cal date: 1234.56.78 [ 18/12/2015 18:33:00 ] IMEI: [ 18/12/2015 18:33:00 ] Checking Super user right... true [ 18/12/2015 18:33:00 ] Writing nv data... OK [ 18/12/2015 18:33:00 ] Recalculating md5... OK [ 18/12/2015 18:33:00 ] Deleting backup... OK [ 18/12/2015 18:33:00 ] Rebooting phone... OK [ 18/12/2015 18:33:00 ] Write NV Data done [ 18/12/2015 18:33:00 ] [ 18/12/2015 18:34:00 ] Operation: Write CERT [ 18/12/2015 18:34:00 ] Selected model: SM-N910C [ 18/12/2015 18:34:00 ] Software version: 23.7 [ 18/12/2015 18:34:00 ] [ 18/12/2015 18:34:00 ] Checking certificate file... OK [ 18/12/2015 18:34:00 ] KEY ID: 0065 [ 18/12/2015 18:34:00 ] Waiting ADB device... OK [ 18/12/2015 18:34:00 ] Reading phone info... [ 18/12/2015 18:34:00 ] Model: SM-N910C [ 18/12/2015 18:34:00 ] Android version: 5.1.1 [ 18/12/2015 18:34:00 ] Product code: [ 18/12/2015 18:34:00 ] Phone version: N910CXXU1COJ5 [ 18/12/2015 18:34:00 ] PDA version: N910CXXU2COJ5 [ 18/12/2015 18:34:00 ] CSC version: N910COLB2COJ5 [ 18/12/2015 18:34:00 ] CSC country code: THAILAND [ 18/12/2015 18:34:00 ] CSC sales code: THL [ 18/12/2015 18:34:00 ] HW version: [ 18/12/2015 18:34:00 ] Phone S/N: [ 18/12/2015 18:34:00 ] Modem board: DB7450R [ 18/12/2015 18:34:00 ] RF cal date: 1234.56.78 [ 18/12/2015 18:34:00 ] IMEI: [ 18/12/2015 18:34:00 ] Checking Super user right... true [ 18/12/2015 18:34:00 ] Reading nv data... OK [ 18/12/2015 18:34:00 ] Analisis NV data... error [ 18/12/2015 18:34:00 ] Security damaged |
The Following User Says Thank You to nongmobile For This Useful Post: |
12-19-2015, 12:54 | #5 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Left out from our gsm field Age: 29
Member: 2386560 Status: Offline Sonork: NOW I DON'T USE IT Thanks Meter: 561 | here is u r 100% tested solution please restore your efs from back folder [C:\Program Files\Z3X\Samsung\SamsungToolPRO\backup\EFS] then reset efs then write cert..................and post result here ........ if my post useful dont forget press thanks Last edited by vickyjadhav6161; 12-19-2015 at 13:01. |
12-20-2015, 08:10 | #7 (permalink) |
Member: 617073 Status: Offline Sonork: 100.1611349 Thanks Meter: 316 | after write nv data security ok but when i write cert file show error check log BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-N910C Software version: 23.7 Checking certificate file... OK KEY ID: 0065 Waiting ADB device... OK Reading phone info... Model: SM-N910C Android version: 5.0.1 Product code: Phone version: PDA version: N910CXXU1BOC5 CSC version: N910COJV1BOC2 CSC country code: Egypt CSC sales code: EGY HW version: Phone S/N: RF8FB1TQF5D Modem board: RF cal date: IMEI: Checking Super user right... true Reading nv data... OK Analisis NV data... OK Writing nv data... OK Rebooting phone... OK Waiting ADB device... OK Reading phone info... Model: SM-N910C Android version: 5.0.1 Product code: Phone version: PDA version: N910CXXU1BOC5 CSC version: N910COJV1BOC2 CSC country code: Egypt CSC sales code: EGY HW version: Phone S/N: RF8FB1TQF5D Modem board: RF cal date: IMEI: Initialization AT RIL... error Done with Samsung Tool PRO v.23.7 |
