Old 05-27-2019, 02:37   #1 (permalink)
CANNYCOMPUTERS's Avatar
Member: 2115142
Thanks Meter: 50
Samsung note 5 sm-n9208dx
THIS MODEL NOT SHOWING IN LIST
ISSUE:
EMERGENCY CALL ONLY
IMEI AND BASEBAND IS OK
REPAIR INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Fill values what you need to repair.
6. Press 'Repair' button.
7. Press 'Patch Certificate' if you have network problem after repairing.
7. Press 'Reset EFS' if you need to reset it.
Be carefully, do not perform this without necessity. Backup will be created automatically.
Repair DRK (Use it if you have DRK damaged (phone stuck on boot)):
1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Press 'Repair DRK' button.
Operation: Info
Selected model: SM-N9208
Software version: 36.2
Searching Samsung modem... detected COM7
Reading phone info...
Model: SM-N9208
AP version: N9208XXS5CRH1
CSC version: N9208OLB3CQJ1
CP version: N9208XXU5CRH1
Product code: XTC
Phone SN: R28H11KXXXX
IMEI: 35567652123XXXX
IMEI2: 350987898XXXXX
Unique number: 1115FBC3BB9F2D04
Reading IMEI... OK
IMEI: 3556765212XXXXX (SIGN: NG_SIGN)
IMEI 2: 35098789XXXX (SIGN: NG_SIGN)
Done with Samsung Tool PRO v.36.2
Page generated in 0.13526 seconds with 7 queries
