09-22-2013, 08:58 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: ..:INDIA:..ONGOLE
Member: 642004 Status: Offline Thanks Meter: 100 | Samsung Rex 70 S3802 succesfully flash by Z3x flash file Hotfile.com: One click file hosting: S3802DDMC3.rar flasher Hotfile.com: One click file hosting: S3802_flashtool_e2_v4.102.zip Notice: You have to know that we are not responsible for any error may happen during the update, So you can update your device on your own risk. Downloads & Tools: - Samsung S3802 REX 70 DUOS Firmware Package (Extract after downloading). - Samsung S3802 FlashTool (Extract after downloading). - Suitable USB cable for Samsung S3802. - A computer with Windows OS installed. Samsung S3802 REX 70 Firmware Update Steps: - Turn off the device and take out its SIM and memory cards. - From the flasher folder run FlashTool_E2.exe - Now open the extracted firmware folder and you will see 5 files, Drag and drop them at the flashtool window in this order: S3802ODDMC5_USER.dfat S3802xxxxx_BSY.fls S3802xxxxx_CDS.fls S3802ODDMC5_CUST.dfat S3802ODDMC5_ROOT.dfat - Now Check these settings: Custom Order (Must be checked). Erases Calibration! : Select (Unconditional erase each area before write). Baud Rate: 921600 Communication Driver: IMC USB Driver. - Now you can click on Next button, And a new window will appear. - Click on Start USB1 button. - Now you have to connect your Samsung S3802 REX 70 Duos to PC using the USB cable. - There are more than one way to connect your phone, You can try any one of the following: 1- With the phone's battery in, Press and hold Home key then connect the USB cable to it. 2- With the phone's battery in, Press and hold Volume Down + Volume Up keys, Then connect the USB cable to it. 3- Connect the USB cable to phone without battery, After it is detected you can insert the battery. - When Windows detects the device it will ask for Drivers, So you have to browse for the FlashUSB_Driver_1_0_1_0 folder inside the FlashTool folder. - After the FlashTool starts the update process you have to wait for some minutes. - When the operation is done, You will see a Success word, And that means it was done right. - Disconnect the USB cable from phone. - With your Samsung Star 3 Duos on, Do a full reset by this code *2767*3855# - Now when your phone restart it will be ready for using with its new firmware. |
The Following 3 Users Say Thank You to kishore ch For This Useful Post: |
09-22-2013, 11:37 | #3 (permalink) | |
No Life Poster Join Date: May 2008 Location: Bangladesh
Member: 782943 Status: Offline Sonork: 100.1601067 Thanks Meter: 204 | Quote:
The Following User Says Thank You to raselcox For This Useful Post: |
12-14-2013, 10:32 | #6 (permalink) |
Freak Poster Join Date: Mar 2005 Location: sirsa Age: 56
Member: 123740 Status: Offline Sonork: [email protected] Thanks Meter: 28 | mr kailash procedure in picture is correct only not which is below taken from tsar |
The Following User Says Thank You to talwaria For This Useful Post: |
05-06-2014, 13:51 | #9 (permalink) | |
Freak Poster Join Date: Aug 2007 Location: in iOs
Member: 563648 Status: Offline Sonork: 100.1594523 Thanks Meter: 87 | Quote:
This Is Z3X Selected model: S3802 Selected port: COM4 USB Serial Port Selected port speed: 921600 Waiting phone... OK Sending preloader... OK Sending loader... OK Checking Flash ID... OK Detected Flash ID: 00B100EC Erasing flash... OK Sending BIN/BSY (psi.fls)... OK Sending BIN/BSY (slb.fls)... OK Sending BIN/BSY (CATFISH2250_PRE.fls)... OK Sending BIN/BSY (CATFISH2250_PAGING.fls)... OK Sending CDS (CATFISH2250.fls)... OK Sending CUST (GT-S3802_OXF_CUST.dfat)... OK Sending ROOT (GT-S3802_OXF_ROOT.dfat)... OK Sending USER (GT-S3802_OXF_USER.dfat)... OK Flashing done (time - 00:02:54) Done with Samsung Tool v.17.2 Done with Samsung Tool v.17.2 | |
