10-04-2013, 16:56 | #1 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Somewhere on earth
Member: 2014742 Status: Offline Thanks Meter: 167 | Samsung S275m Phone Lock/Unlock It has a phone lock password so I can't enter *2767*3855# to wipe it. Is there any other way? Button combination? I did a lot of searching but came up empty. I also wanted to unlock hopefully after finding a way to reset it. |
01-23-2014, 05:56 | #3 (permalink) |
Member: 2014742 Status: Offline Thanks Meter: 167 | Would someone elaborate on the SOS solution. I searched online but couldn't find anything that worked for this model. Also to the Z3X team: please add this as it's becoming a pretty common phone. |
02-21-2017, 05:11 | #7 (permalink) |
No Life Poster Join Date: May 2005 Location: bridgetown Age: 59
Member: 146939 Status: Offline Sonork: 100.1609615 Thanks Meter: 245 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. Press 'Flash' button. 3. Connect phone in flash mode (reconnect battery and connect USB cable). If you have dead phone, then try to connect it pressing 'Hold'+'vol.up' button and connect USB cable. Operation: Flash Selected model: SGH-S275M Software version: 27.7 Load model info... Ok Loading BIN PTT file... Ok Reconnect battery and connect phone to USB cable Phone detected Checking device descriptions... Ok Link type set to USBH Reading OTP... Ok OTP register: 00000000 Unprotected device detected Reading product ID... Ok Product ID: 0x1066738D1E62D62C Reading SCROM version SCROM version - PNX6729 v. 1.10 Chipset version - 3C11 Downloading Loader in Internal RAM... Ok Wait for device... Ok Checking device descriptions... Ok Loader verison... 7.5.16 NAND flash memory SSG_K522H1HACA-A060 detected Flash memory parameters Capacity params: 2 Datawidth - 2048 Block number - 64 Block size - 0 Buffer prog. Timing params: 2 ms erase block time - 250 us write buffer time Send Loader and NAND Flash Parameters... Loader parameters Write Test flash params: 0x0 Test Address - 0 Test size Buffer params: 3 Buffer type - 134217728 Buffer size - 32768 Tansfert size - 32768 Tansfert RAW size Bad Block params: 42 Bad block reservoir size SW Boot version: 5 Get First Block... Ok Prepare FirstBlock... Ok Init Bad Block Managment... Ok Send Verify Cmd... Ok Erasing Partition_1... Ok Erasing Partition_2... Ok Erasing Partition_3... Ok Erasing Partition_4... Ok Erasing Partition_5... Ok Erasing Partition_6... Ok Erasing Partition_7... Ok Erasing Partition_8... Ok Erasing Partition_9... Ok Erasing Partition_10... Ok Erasing Partition_11... Ok Erasing Partition_12... Ok Erasing Partition_13... Ok Check Protected Device... Ok Programming Partition_1 Prepare CRC32... Ok Set Partition Params... Ok Download Partition_1 IMAGE... Ok Checking CRC32... Ok Programming Partition_2 Prepare CRC32... Ok Set Partition Params... Ok Download Partition_2 IMAGE_S... Ok Checking CRC32... Ok Programming Partition_3 Prepare CRC32... Ok Set Partition Params... Ok Download Partition_3 LCDACT... Ok Checking CRC32... Ok Programming Partition_4 Prepare CRC32... Ok Set Partition Params... Ok Download Partition_4 RBDELTA... Ok Checking CRC32... Ok Programming Partition_5 Prepare CRC32... Ok Set Partition Params... Ok Download Partition_5 RBUA... Ok Checking CRC32... Ok Programming Partition_6 Prepare CRC32... Ok Set Partition Params... Ok Download Partition_6 MAIN... Ok Checking CRC32... Ok Programming Partition_7 Prepare CRC32... Ok Set Partition Params... Ok Download Partition_7 PAGED... Ok Checking CRC32... Ok Programming Partition_8 Prepare CRC32... Ok Set Partition Params... Ok Download Partition_8 LFS... Ok Checking CRC32... Ok Programming Partition_9 Prepare CRC32... Ok Set Partition Params... Ok Download Partition_9 app... Ok Checking CRC32... Ok Programming Partition_10 Prepare CRC32... Ok Set Partition Params... Ok Download Partition_10 app2... Ok Checking CRC32... Ok Programming Partition_11 Partition_11 sysv is empty. Nothing to program. Flashing done (time - 00:03:01) Done with Samsung Tool PRO v.27.7 flash phone and it will reset phone lock code |
