Old 10-10-2009, 18:43   #1 (permalink)
Stylo_GSM's Avatar
Member: 177235
Sonork: 111568
Thanks Meter: 132
Samsung S3650 UNLOCKED!!! [Report OK]
Works like a charm, Read codes by selecting s5230 model, And enter code manually.
Job done!
The Following 20 Users Say Thank You to Stylo_GSM For This Useful Post:
Old 10-10-2009, 18:53   #2 (permalink)
Member: 633
Thanks Meter: 37
Job done!
Can u post screenshot?
Zoio
Old 10-10-2009, 18:57   #3 (permalink)
Stylo_GSM's Avatar
Member: 177235
Sonork: 111568
Thanks Meter: 132
It works , that matters,
Old 10-10-2009, 21:52   #4 (permalink)
GSMsurgeon's Avatar
Member: 6524
Thanks Meter: 243
Maybe 2nd in the world !!
WOW !!! GREAT JOB
Becouse UST not working with s3650....maybe 1st done by nspro..2nd by z3x tested by STYLO...Great job..Thank you verry much..
i fed up one s-3650 by ust...not connecting...
The Following 2 Users Say Thank You to GSMsurgeon For This Useful Post:
Old 10-11-2009, 00:04   #5 (permalink)
Member: 256010
Thanks Meter: 11
s3650
Job done!
yes is working i did unlock as well just select s5230
Old 10-11-2009, 00:08   #6 (permalink)
Member: 256010
Thanks Meter: 11
samsung s8000 i unlock 2
thanks mr blanq foer good advice first 1 idid flash pacht drict unlock after flash normal file unlock away .after i did flash pachrt read code no problem
The Following User Says Thank You to omerdagli For This Useful Post:
Old 10-13-2009, 10:45   #7 (permalink)
Member: 996827
Thanks Meter: 3
just one problema
i did it like i would do a s5230 and now i have no network
can someone help me
Old 10-13-2009, 11:13   #8 (permalink)
Member: 150570
Thanks Meter: 52
Originally Posted by stevemiana View Post
just one problema
can someone help me
Did you read codes and inserted codes manually into phone?
For network problem . eeprom rewrite and reflash normally does the job. But wait till Z3X support answers.
marty
Old 10-13-2009, 11:36   #9 (permalink)
Member: 996827
Thanks Meter: 3
marty
with are the code that i have to use and where do i put them
thanks
Old 10-14-2009, 11:23   #10 (permalink)
Member: 996827
Thanks Meter: 3
Factory SW: S3650BFII1_II3
UniqueNumber: 76200000001234
MemoryPhone: K522H1HACC(S3650)
Phone IMEI: 35488103113656 /2
Phone S/N: R9YS960993
Phone Bluetooth ID: 60 D0 A9 07 6B 21
Phone SW: S3650BFII1_II3
Phone HW: MP 0.600
Phone CalData ver: 20090915
Detecting UART port..... OK
Calculating security.... OK
Please wait decrypt code ... OK
[FREZEE]:59682050
[NET LOCK]:38697964
[Subset LOCK]:00000000
[SP LOCK]:00000000
[CP LOCK]:00000000
Decrypted time: 47 sec
Elapsed time: 153 second, sw ver: 3.3 beta 0018
anything wrong here???
Old 10-14-2009, 21:20   #11 (permalink)
Member: 812097
Thanks Meter: 5
What cable have you used?
The Following User Says Thank You to Otreb For This Useful Post:
Old 10-14-2009, 21:24   #12 (permalink)
nasirkhan007's Avatar
Member: 553445
Sonork: 100.1585581
Thanks Meter: 8,185
Use E210 Cable RJ-45 + USB
The Following 3 Users Say Thank You to nasirkhan007 For This Useful Post:
Old 10-14-2009, 21:24   #13 (permalink)
Service4Gsm.de's Avatar
Member: 811992
Sonork: 100.1584257
Thanks Meter: 162
thanks for the information
The Following User Says Thank You to Service4Gsm.de For This Useful Post:
Old 10-19-2009, 23:49   #14 (permalink)
Member: 554846
Thanks Meter: 49
Simple process to unlock S5230, or S3650
Download z3x samsung 2g Toolv3.3beta0007
n select j750 cable n press direct unlock,
when software says
''disconect RJ45 cable and connect data cable (APCBS10BBE or compatible)to phone''
then conect E210 cable (RJ45 with z3x) n connect (usb with direct laptop)
Phone detect - wait for unlock
Net locks - cleared
Reset Phone code to - >00000000
Reset Sim Block code to - >00000000
Elapsed time:209 second ---> with soft version ->3.3beta 0007
THNX
Old 10-19-2009, 23:50   #15 (permalink)
Member: 554846
Thanks Meter: 49
both phones are same to unlock
how to samsung s3650 unlock DALVINDER HWK 73 03-05-2013 02:38
unlock E1105t samsung with e1310m .....[REPORT OK] MGT SOFTWARE PolarBox 3 5 03-15-2010 03:52
samsung s3650 unlock???? viral123 UST Pro II 0 03-12-2010 16:46
Corby S3650 direct unlocked [Report OK] rea1One Z3X-Team Products 0 11-14-2009 06:27
samsung a767 unlocked [Report OK] gseme Z3X-Team Products 0 09-19-2009 21:00
Page generated in 0.45179 seconds with 9 queries
