05-05-2015, 05:49 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: PAKISTAN
Member: 233108 Status: Offline Sonork: 100.1587561 Thanks Meter: 86 | Samsung S5 G900f unlock done ver 5.0 samsung tool pro BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Choose diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-G900F Selected port: COM1 Communications Port, Software version: 21.0 Checking certificate file... OK KEY ID: 0478 Waiting ADB device... OK Reading phone info... Model: SM-G900F Android version: 5.0 Product code: Not Active Phone version: G900FXXU1BOC7 PDA version: G900FXXU1BOC7 CSC version: G900FO2U1BOC1 CSC country code: UK & IRE CSC sales code: O2U HW version: Phone S/N: RF8F40243FE Modem board: MSM8974PRO RF cal date: NONE IMEI: Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0478 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.21.0 |
The Following User Says Thank You to love-for For This Useful Post: |
