11-20-2012, 14:53 | #1 (permalink) |
No Life Poster Join Date: Feb 2010 Location: india Age: 44
Member: 1229072 Status: Offline Sonork: 100.1624007 Thanks Meter: 1,644 | samsung s5222 imei change problem pls help me z3x team Selected model: S5222 Selected com port: COM12 Selected speed port: 921600 Attention !!! Use this operation after flashing phone Search diag port... Timeout Repair - fail Elapsed time: 93 second, sw ver: 3.5.0038 ------------------------------------------------------------------------------- Selected model: S5222 Selected com port: COM12 Selected speed port: 921600 Attention !!! Use this operation after flashing phone Search diag port... Timeout Repair - fail Elapsed time: 93 second, sw ver: 3.5.0038 ------------------------------------------------------------------------------- |
01-26-2013, 14:45 | #5 (permalink) |
Insane Poster Join Date: Jan 2010
Member: 1219466 Status: Offline Thanks Meter: 52 | Selected model: S5222 Selected com port: COM50 Selected speed port: 921600 Attention !!! Use this operation after flashing phone Search diag port... OK (COM221) Phone SN: RZ1C63HVQR Deactivate MSL - OK Phone master OLD IMEI: 3522740********/00 Phone slave OLD IMEI: 3522750********/00 Phone NEW master IMEI: 35604********9/00 Phone NEW slave IMEI: 3560480********/00 Repair - ok Elapsed time: 45 second, sw ver: 3.5.0040 |
08-03-2013, 18:20 | #6 (permalink) | |
Freak Poster Join Date: Mar 2005 Location: ALEX MY BIG LOVE Age: 45
Member: 129706 Status: Offline Thanks Meter: 23 | Help me Quote:
can you give me details to repair imei give me your phone version i tray to flash many version same probleum deactivate msl error help me thanx | |
10-31-2013, 09:10 | #7 (permalink) |
Junior Member Join Date: Feb 2008
Member: 714492 Status: Offline Thanks Meter: 6 | Selected model: S5222 Selected com port: COM2 Selected speed port: 921600 Attention !!! Use this operation after flashing phone Search diag port... OK (COM29) Phone SN: RZ1C613LL1 Deactivate MSL - OK Phone master OLD IMEI: 11111111111111/00 Phone slave OLD IMEI: 00000000000000/00 Phone NEW master IMEI: 35195203572895/00 Phone NEW slave IMEI: 35268604275126/00 |
05-09-2014, 07:25 | #10 (permalink) |
No Life Poster Join Date: Mar 2013 Location: India Age: 29
Member: 1900418 Status: Offline Sonork: Not Available Yet Thanks Meter: 93 | first off all flash ur phone ,then click imei repairwithout flash not possible |
The Following User Says Thank You to GSMFEROZEPUR For This Useful Post: |
05-25-2014, 15:09 | #12 (permalink) |
Junior Member Join Date: Jul 2010 Location: BHIWANDI
Member: 1337119 Status: Offline Thanks Meter: 5 | Samsung s5222 imei repair done with Z3X Selected model: S5222 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 921600 Connect phone in flash mode Waiting phone... OK Sending preloader... OK Sending loader... OK Checking Flash ID... OK Detected Flash ID: 003000EC Reading security... OK Writing security... OK Rebooting phone... OK If phone not powered ON - turn ON phone Searching Samsung modem... detected COM40 Reading phone info... Model: GT-S5222 Country code: OPENÇâ Factory SW: S5222DDLC5_ODDLD2 Unique number: 27160000732007 Memory phone: K5W1G12ACP(S5222)S Software version: S5222XXLL1/S5222OXELK1 IMEI: 00000000000000 Bypass MSL... OK Repairing IMEI... OK Repairing Slave IMEI... OK Repair done Done with Samsung Tool v.17.5 Done with Samsung Tool v.17.5 |
09-10-2014, 09:07 | #13 (permalink) | |
Freak Poster Join Date: Sep 2012 Location: Loading! Age: 34
Member: 1813502 Status: Offline Sonork: 100.1623430 Thanks Meter: 182 | Quote:
How did u do my bro because Iam trying since many time but it is showing me this " Selected model: S5222 Selected com port: COM77 Selected speed port: 921600 Attention !!! Use this operation after flashing phone Search diag port... OK (COM77) Deactivate MSL - fail Repair - fail Elapsed time: 5 second, sw ver: 3.5.0033" and I am doing this procedure after flashing completely please give me any best solution fast I am wating | |
01-30-2015, 13:01 | #15 (permalink) |
Freak Poster Join Date: May 2009 Location: Morigaon (ASSAM) INDIA
Member: 1030555 Status: Offline Sonork: ******** Thanks Meter: 26 | Samsung S5222 successfully Rebuild IMEI number with z3x tool V18.8. Procedure First select the model no need to apply flash file and put IMEI no in repair section and put also serial no. Then press repair then connect the USB cable to phone without battery at last when ask to power on the set then used battery and switch on the mobile and process done. http://postimg.org/image/dhxtq8au5/ |
