04-16-2015, 07:51 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: +919304287474 Age: 41
Member: 714710 Status: Offline Sonork: offline Thanks Meter: 1,017 | samsung s5282 flashing problemes after flash show computer simbole Code: Selected model: S5282 Selected port: Selected port speed: 115200 File analysis... OK Total file size: 0x394D5198 Searching USB Flash Interface... detected COM52 Setup connection... OK Reading PIT from phone... OK Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Pit\S5282_16-4-2015_12-12-0.pit Sending SPL.img... OK Sending sboot.bin... OK Sending param.lfs... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending userdata.img... OK Sending SPRDCP.img... OK Sending SPRDDSP.img... OK Sending nvitem.bin... Error Done with Samsung Tool v.18.9 Done with Samsung Tool v.18.9 main foult error Code: Sending nvitem.bin... Error |
04-16-2015, 09:08 | #3 (permalink) |
Member: 714710 Status: Offline Sonork: offline Thanks Meter: 1,017 | thanks dear Code: Welcome to Octoplus/Octopus Box Samsung software version 1.8.0 ----------------------------------------------------------------------------------- To connect GT-I9500 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: CODE_S5282XXAMEA_1231218_REV03 _user_low_ship.oct Please put the phone into Download Mode and connect USB cable. To put GT-S5282 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing KERNEL section... KERNEL section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing system section... system section has been written successfully. Writing userdata section... userdata section has been written successfully. Writing modem section... modem section has been written successfully. Writing DSP section... DSP section has been written successfully. Writing FIXNV2 section... FIXNV2 section has been written successfully. Writing CSC section... CSC section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. |
