11-23-2014, 10:25 | #1 (permalink) |
Freak Poster Join Date: May 2010 Location: New Delhi
Member: 1314849 Status: Offline Sonork: 100.1659284 Thanks Meter: 8 | samsung s5360 usb device not recognised Selected model: S5360 Selected port: COM4 USB Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x0E917698 Searching USB Flash Interface... not found Done with Samsung Tool v.18.3 Plz me i tried on different mobile but in every mobile same problem |
11-23-2014, 12:22 | #2 (permalink) |
Freak Poster Join Date: Mar 2014 Location: Heart
Member: 2144988 Status: Offline Sonork: 100.1655364(Offline) Thanks Meter: 217 | Check Usb Port of Pc Change Slot and Also Check usb cable at this time you Using Almost This Problem Related From Usb Charjing Jack but You Saying U Also Check on other mobile Which O.S. You Used? Wbr Hifzul Amin |
11-23-2014, 16:46 | #6 (permalink) | |
No Life Poster Join Date: May 2012 Location: BHARAT
Member: 1766148 Status: Offline Sonork: 100.1614494 Thanks Meter: 490 | Quote:
Otherwise It maybe due to bad USB Port on Motherboard / Corrupted drivers on OS. You should try by formatting your PC / correcting drivers first. | |
11-23-2014, 16:55 | #7 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1960916 Status: Offline Thanks Meter: 0 | what do you want to do the unit,you want it to flash or unlock.,?if you want it to flash then put it in downloadmode,but if need to unlock try to check the settings, if already in usb debbuging mode. or update all your drivers,install new samung kies. hope it will help you.. |
11-23-2014, 17:28 | #8 (permalink) | ||
No Life Poster Join Date: Feb 2013
Member: 1890459 Status: Offline Sonork: 100.1627340 Thanks Meter: 149 | Quote:
