01-04-2017, 14:20 | #1 (permalink) |
No Life Poster Join Date: Mar 2009
Member: 997544 Status: Offline Thanks Meter: 71 | Samsung s6 edge restarting issue I flashed the device for restarting issue (current version 6.0.1) still the phone is restarting then downgrade to 5.1.1 still not working. I replaced the battery and changed the ON/OFF switch for this,still not working. I have more than 5 pieces in this model with the same problem. Any solution for this would be big help for me from the FORUM members. Thanks |
01-05-2017, 10:27 | #5 (permalink) |
Junior Member Join Date: Jun 1999 Location: Europe
Member: 277 Status: Offline Thanks Meter: 8 | Combination .. This small file, designed for developers, So It stops all applications except settings and board ENG. Info, So If the phone keeps restarting, then you must detect Ur Board H/W. Thanks Gsm_Trade |
01-05-2017, 12:22 | #6 (permalink) |
No Life Poster Join Date: May 2016
Member: 2577670 Status: Offline Thanks Meter: 883 | I have the same problem with a G925V. After one minute, the phone will turn off but if it is connected to a charger, the phone will reboot/restart by itself. I also changed the battery and flashed it with all possible 4 file firmwares but nothing changes. |
01-10-2017, 14:17 | #7 (permalink) | |
Member: 997544 Status: Offline Thanks Meter: 71 | Quote:
Is there any hardware solution for this issue,any IC related solution or any replacing part plz post me dear members Thanks | |
The Following User Says Thank You to SYRYA TEL For This Useful Post: |
