Old 06-02-2015, 20:34   #31 (permalink)
Member: 2194977
Originally Posted by kamall View Post
what the solution or there is no solution
You need to backup efs from a good phone then write on your phone.
Old 06-03-2015, 16:40   #32 (permalink)
Member: 1360988
Thanks Meter: 89
I have repaired my imei but i want to edit it
Old 06-13-2015, 13:34   #33 (permalink)
Cheater -Don't Deal with him-
Member: 260694
Thanks Meter: 16
i have succefuly repaired imei on s6 with efs and cert from another phone and now i wont to edit imei is it possible ?
thanks
Can you please share with me your EFS ans Cert; i hqve same pb; THX
Old 06-19-2015, 07:39   #34 (permalink)
Member: 839673
Sonork: pastorshaggy
Thanks Meter: 66
facing same problem samsum g920f here ime is 3500000000000006 it was brought to my workshop like that is there any way to repair ime
Old 06-19-2015, 11:28   #35 (permalink)
Member: 653105
i got the same problem with my G920W8 , no network , signal bar always prohibition signs.. i hope add NV read/write in next update....
Old 06-22-2015, 12:08   #36 (permalink)
slim_j's Avatar
Member: 1029079
Thanks Meter: 61
is there a solution for this...?
can anybody share efs and cert if possible for G920F
Old 06-25-2015, 09:30   #37 (permalink)
Member: 1093471
Thanks Meter: 25
i already solve mine via Octopus box (sorry z3x team i did not try to write cert on your box )
INFO : 6/7/2015 12:22:53 PM > Platform: Samsung Android
INFO : 6/7/2015 12:22:53 PM > Selected port: COM293
INFO : 6/7/2015 12:22:53 PM > Selected model: SM-G920F
INFO : 6/7/2015 12:23:00 PM > Selected file: D:\Back up\Z3X Files\QCN\S6 S6 Edge\cert-sm-g920f_35XXXXXXXXXXXXXXXXX_rXXXXXXXXXX.cert
WARN : 6/7/2015 12:23:02 PM > Perform the following steps:
WARN : 6/7/2015 12:23:02 PM > 1. Connect phone via UART cable to the Box.
WARN : 6/7/2015 12:23:02 PM > 2. Note: phone screen must be active
INFO : 6/7/2015 12:23:02 PM > Connecting to phone, please wait...
INFO : 6/7/2015 12:23:07 PM > Found phone on COM9
INFO : 6/7/2015 12:23:07 PM > Phone connected successfully
INFO : 6/7/2015 12:23:07 PM > Checking Certificate file...
INFO : 6/7/2015 12:23:07 PM > Certificate file successfully checked
INFO : 6/7/2015 12:23:07 PM > Writing new phone IMEI...
INFO : 6/7/2015 12:23:18 PM > Checking certificate compatibility...
INFO : 6/7/2015 12:23:18 PM > Certificate is compatible
INFO : 6/7/2015 12:23:24 PM > Certificate has been written successfully
INFO : 6/7/2015 12:23:24 PM > Please, restart the phone to apply changes
now G920f 100% working
Old 06-27-2015, 01:37   #38 (permalink)
slim_j's Avatar
Member: 1029079
Thanks Meter: 61
Can you share the Efs and cert if possibli
Old 07-19-2015, 02:40   #39 (permalink)
Member: 2175198
g920f imei 350000000000006 lutfen hwoe beakuo imei oled
Old 07-22-2015, 23:45   #40 (permalink)
Member: 2432576
Question please an s6 efs
thanks
please can you give me an s6 efs to repair mine?
Old 07-23-2015, 17:38   #41 (permalink)
Member: 2082183
Sonork: 100.1638535
Thanks Meter: 53
Originally Posted by blang View Post
no we cant add any imei repair and network repair for new qualcomm.
i think 1000times told that
fixed check
http://forum.gsmhosting.com/vbb/f684...topus-1972003/
Old 07-25-2015, 15:21   #42 (permalink)
Ahmed Zitoon's Avatar
Member: 187853
Sonork: 100.1609563
Thanks Meter: 1,201
Originally Posted by moroccounlock View Post
i use octopus box but its the same problem security damage , with no network
when i write cert only 1 imei can change it , not the both are repaired
Old 08-22-2015, 10:53   #43 (permalink)
Member: 1062495
Sonork: Niraj Thapa 9841450574
Thanks Meter: 13
g920f 5.1.1 unlock but no sim card emergency call only Security damaged or incorrect key how to my problem solve ? gsm forum youser bro......
Old 08-22-2015, 20:08   #44 (permalink)
Member: 1744748
Thanks Meter: 753
Fix the dev root key (security damaged) and ALL YOUR problems will go away...
Old 08-25-2015, 06:18   #45 (permalink)
chubbie's Avatar
Member: 281801
Sonork: 100.1608672
Thanks Meter: 158
what you mean by dev root key???
Page generated in 0.20487 seconds with 8 queries
