12-20-2017, 18:57 | #94 (permalink) |
No Life Poster Join Date: Aug 2009 Location: Germany
Member: 1087322 Status: Offline Thanks Meter: 173 | hi i have S6 edge 7.0 SM-G925F. The Imei is 3500000000000006 S/n is none i become this error in z3x Code: Operation: Write CERT Selected model: SM-G925F Software version: 30.1 Waiting ADB device... OK Reading phone info... Model: SM-G925F Android version: 7.0 Product code: Phone version: G925FXXU5EQCD PDA version: G925FXXU5EQDF CSC version: G925FDBT5EQD1 CSC country code: Germany CSC sales code: DBT HW version: Phone SN: Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-04-01 RF cal date: IMEI: 350000000000006 Checking Super user right... true Reading NV data... OK Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.30.1 pls help b.r Afghanboy Last edited by Afghanboy; 12-20-2017 at 19:04. |
12-20-2017, 19:09 | #95 (permalink) |
Member: 1087322 Status: Offline Thanks Meter: 173 | Dark reapir come error Code: Operation: Repair DRK Selected model: SM-G925F Software version: 30.1 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... COM3 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Recovery build version: 6.0.1 Boot version: G925FXXU5EQDF Platform: exynos7420 Boot serial: 05160300672d0348 Product board: zerolte Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... NG! Writing DRK... error () Done with Samsung Tool PRO v.30.1 |
11-13-2018, 14:53 | #96 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | i have sole this one just write 3 files modem cm sboot for same mobile firmware bild and v 100% imei back without any creat and efs |
11-15-2018, 00:13 | #98 (permalink) |
Junior Member Join Date: Oct 2018
Member: 2869215 Status: Offline Thanks Meter: 1 | Hi, I got Samsung Galaxy SMG925V S6 Edge tried to do FRP,I use SMG 925F and I got the message as FRP successfully, please see below: Platform: SAMSUNG Selected model: SM-G925F Reset FRP/ Reactivation lock operation for SM-G925F will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-G925F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Advanced mode! Firmware write started. Writing Custom section... Custom section has been written successfully. Firmware writing successfully completed. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 1.4.9.0 Software version. Once I reset the phone and turn on its asking me Samsung account is this phone is not unlocked? can anyone give me suggestions or advice that will be great help? Thanks TWS |
11-15-2018, 00:46 | #99 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
11-16-2018, 14:11 | #101 (permalink) |
No Life Poster Join Date: Apr 2005 Location: mars
Member: 132881 Status: Offline Thanks Meter: 105 | Just a word of advice.When you are done repairing ensure you unroot your phone.Ihave seen that a lot of times if you leave it rooted it will corrupt againn.How that happens,i have no idea but it happens |
