06-08-2017, 09:18 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 775581 Status: Offline Thanks Meter: 186 | Samsung S6 unfreeze device reflashed with other region no result. it has pin code, after reflashed pin still there, so i can't enter the menu. how to unlock this device ? |
06-08-2017, 14:28 | #2 (permalink) |
Freak Poster Join Date: Oct 2014 Location: puerto rico
Member: 2282504 Status: Offline Thanks Meter: 50 | If I am not mistaken in the z3 box when performing read unlock code, it also gives the one of unfreeze code |
The Following User Says Thank You to ltindi32 For This Useful Post: |
06-10-2017, 06:00 | #8 (permalink) |
Member: 775581 Status: Offline Thanks Meter: 186 | i'm not pretty sure if custom rom could fix this trouble and i have no idea which custom rom is stable for this g920i : pixel rom, noble rom or xtrestolite or maybe others ??? |
06-10-2017, 07:47 | #9 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
after that u can stock for stable | |
The Following User Says Thank You to CHANDARAKK For This Useful Post: |
06-10-2017, 09:05 | #12 (permalink) |
No Life Poster Join Date: May 2006 Location: heLL and beY0nd
Member: 281801 Status: Offline Sonork: 100.1608672 Thanks Meter: 158 | ==>>TRY to RESET EE lock/FRP remove, both cant be proper frozen lock, have to be one of those PERSISTENCE LOCKDOWN. Or ==>>Find any of those REPAIR firmware that has PERSIST image and Flash......... ~~THANKS, if helpful~~ |
The Following User Says Thank You to chubbie For This Useful Post: |
06-11-2017, 03:43 | #13 (permalink) | |
Member: 775581 Status: Offline Thanks Meter: 186 | Quote:
i have no idea about repair firmware. | |
06-11-2017, 04:21 | #14 (permalink) |
Junior Member Join Date: Aug 2015
Member: 2441390 Status: Offline Thanks Meter: 3 | Try flashing TWRP recovery, full wipe then install official firmware Sent from my HUAWEI VNS-L31 using Tapatalk |
The Following User Says Thank You to geek343 For This Useful Post: |
06-11-2017, 04:51 | #15 (permalink) | |
keep stuck on unfreeze device screen. seems like sticky on device i plan to read codes (freeze code) with z3x, anybody have idea/trick how to enable usb debbuging with that blocked screen (through adb command or other method), so z3x can read the adb port ? | |
