Samsung S7 G930v FRP locked,succesfully removed. Hi just wanna share this simple trick. Samsung S7 G930v FRP locked,succesfully removed. Info: 1, S7 G930v Verizon 2, 6.0.1 version 3, fresh from format 4, No Combi File needed. 5, No bypass app needed. Procedure. 1,Hold power+volume up+home button, to enter Download Mode. 2,press power+volume down to enter this feature.(the phone will restart). https://preview.ibb.co/jSKQFQ/IMG_1371.jpg 3,press volume to navigate,home button to select. 4,select (usb debug mode) "Usb debugging to "ON"..(#5). https://preview.ibb.co/j0rGN5/IMG_1372.jpg 5,restart and back to Download MOde 6,install ADB driver. 7,Press Reset FRP. https://image.ibb.co/dzusvQ/s7.png 8,dont restart, just set up the phone,go to setting and "ON OEM". 9,reset all and erase. https://image.ibb.co/hHrBpk/IMG_1370.jpg Done. |
but no show but not show debug option pleaswe help |
This is for old firmware versions, new ones >7.0.0 have the adb option removed, so don't waste your time. Also, the instructions are wrong, first you have to enter download mode by Vol Down + Home + Power, release all then press Home twice. Finally hold Vol Down + Power only for about 5 seconds then release power only till the menu appears. |
The instructions are correct and i was able to downgrade and get the 5th option z3x box says Operation: Reset FRP/React/EE Selected model: SM-G930V Selected port: COM5 Z3X BOX Serial Port Software version: 30.8 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... COM3 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Waiting ADB device... timeout Phone not found Done with Samsung Tool PRO v.30.8 I don't know how to "Enable ADB" |
Ok, I got it... 1)Maintenance Mode/5)Enable USB Debugging. 2)Download Mode/Reset FRP_React_EE 3)Once it starts "Waiting for ADB" let it boot to recovery/Factory reset/Reboot Hopefully Your computer recognises the ADB before time runs out and Z3X box handles the rest! 4)It will ask if you want to restore original kernel and I selected Yes. And the rest is history... Operation: Reset FRP/React/EE Selected model: SM-G930V Selected port: COM5 Z3X BOX Serial Port Software version: 30.8 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... COM3 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Model: SM-G930V Android version: 6.0.1 Product code: Phone version: PDA version: G930VVRU4API3 CSC version: G930VVZW4API3 CSC country code: USA CSC sales code: VZW HW version: Phone SN: RF8H92MXE1J Chip name: MSM8996 Modem board: Security patch: 2016-10-01 RF cal date: IMEI: Checking Super user right... true Erasing FRP... OK Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Done with Samsung Tool PRO v.30.8 |
Firmware version G930V-VRU4API3 v6.0.1 is considered "old", but newer ones starting with VRU4BQxx v7.0.0 DO NOT have the ADB-enable option in the maintenance menu, so you must use either a combination or eng-boot to enable adb. This will soon be closed with the introduction of the new RMM security which works independantly from OEM-Unlock... basically it won't let you flash anything else but official stock firmware ... it's gonna be a bitch !! FYI |
Thanks it worked ; first put phone in download mode then hold volume down and power until the phone restart , enable debugging using home button finally use z3x to rest frp |
simple way just write engroot g930v p any vaarriat simple reset frp |
ok 100% thank you good job |
[ 6/30/2018 4:10:49 PM ] Software version: 32.7 [ 6/30/2018 4:10:49 PM ] [ 6/30/2018 4:10:50 PM ] You must activate ADB before reset FRP Yes [ 6/30/2018 4:10:51 PM ] Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes [ 6/30/2018 4:10:52 PM ] Waiting ADB device... OK [ 6/30/2018 4:10:53 PM ] Reading phone info... [ 6/30/2018 4:10:54 PM ] Model: SM-G930V [ 6/30/2018 4:10:54 PM ] Android version: 6.0.1 [ 6/30/2018 4:10:54 PM ] PDA version: G930VVRS4APH1 [ 6/30/2018 4:10:55 PM ] CSC version: G930VVZW4APH1 [ 6/30/2018 4:10:55 PM ] Phone version: G930VVRS4APH1 [ 6/30/2018 4:10:55 PM ] Product code: Not Active [ 6/30/2018 4:10:56 PM ] CSC country code: USA [ 6/30/2018 4:10:56 PM ] CSC sales code: VZW [ 6/30/2018 4:10:56 PM ] Phone SN: RF8H81T891J [ 6/30/2018 4:10:57 PM ] IMEI: 3534250--------- [ 6/30/2018 4:10:57 PM ] HW version: REV0.6 [ 6/30/2018 4:10:57 PM ] RF cal date: 2016.08.18 [ 6/30/2018 4:10:58 PM ] Chip name: MSM8996 [ 6/30/2018 4:10:58 PM ] Modem board: MSM8996 [ 6/30/2018 4:10:58 PM ] Security patch: 2016-09-01 [ 6/30/2018 4:10:59 PM ] Boot Warranty bit: 0 [ 6/30/2018 4:10:59 PM ] Bypass FRP... OK [ 6/30/2018 4:11:01 PM ] For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' |
ANY SOLUTION for latest firmwares (G930VVRU4CRE5_VZW4CRE5) ? I am failing to remove FRP ,I cant downgrade (SW REV CHECK FAIL) |
