Old 07-28-2017, 14:02   #1 (permalink)
smorbe's Avatar
Member: 132735
Thanks Meter: 88
Samsung S7 G930v FRP locked,succesfully removed.
Hi just wanna share this simple trick.
Info:
1, S7 G930v Verizon
2, 6.0.1 version
3, fresh from format
4, No Combi File needed.
5, No bypass app needed.
Procedure.
1,Hold power+volume up+home button, to enter Download Mode.
2,press power+volume down to enter this feature.(the phone will restart).
3,press volume to navigate,home button to select.
4,select (usb debug mode) "Usb debugging to "ON"..(#5).
5,restart and back to Download MOde
6,install ADB driver.
7,Press Reset FRP.
8,dont restart, just set up the phone,go to setting and "ON OEM".
9,reset all and erase.
Done.
The Following 6 Users Say Thank You to smorbe For This Useful Post:
Old 09-12-2017, 13:10   #2 (permalink)
Member: 2536765
but no show
but not show debug option pleaswe help
Old 02-16-2018, 02:46   #3 (permalink)
Member: 2162802
Thanks Meter: 15
downgrade to 6.0.1 and then try again
Old 02-23-2018, 04:27   #4 (permalink)
Member: 2121706
Thanks Meter: 2
what firmware should I use to downgrade?
Old 02-23-2018, 05:06   #5 (permalink)
diddygy's Avatar
Member: 1629133
Thanks Meter: 369
Look in photo is write model firmware
Old 02-23-2018, 10:14   #6 (permalink)
Member: 92260
Thanks Meter: 802
This is for old firmware versions, new ones >7.0.0 have the adb option removed, so don't waste your time.
Also, the instructions are wrong, first you have to enter download mode by Vol Down + Home + Power, release all then press Home twice.
Finally hold Vol Down + Power only for about 5 seconds then release power only till the menu appears.
Old 02-26-2018, 02:39   #7 (permalink)
Member: 2121706
Thanks Meter: 2
The instructions are correct and i was able to downgrade and get the 5th option
z3x box says
Operation: Reset FRP/React/EE
Selected model: SM-G930V
Selected port: COM5 Z3X BOX Serial Port
Software version: 30.8
Checking local file... OK
Searching server... OK
Compare local and server file... OK (up to date)
Searching USB Flash interface... COM3 detected
Setup connection... OK
Reading data from phone... OK
Sending data to phone... OK
Waiting ADB device... timeout
Phone not found
Done with Samsung Tool PRO v.30.8
I don't know how to "Enable ADB"
Old 02-26-2018, 03:27   #8 (permalink)
Member: 2121706
Thanks Meter: 2
Ok, I got it...
1)Maintenance Mode/5)Enable USB Debugging.
2)Download Mode/Reset FRP_React_EE
3)Once it starts "Waiting for ADB" let it boot to recovery/Factory reset/Reboot
Hopefully Your computer recognises the ADB before time runs out and Z3X box handles the rest!
4)It will ask if you want to restore original kernel and I selected Yes.
And the rest is history...
Waiting ADB device... OK
Reading phone info...
Model: SM-G930V
Android version: 6.0.1
Product code:
Phone version:
PDA version: G930VVRU4API3
CSC version: G930VVZW4API3
CSC country code: USA
CSC sales code: VZW
HW version:
Phone SN: RF8H92MXE1J
Chip name: MSM8996
Modem board:
Security patch: 2016-10-01
RF cal date:
IMEI:
Checking Super user right... true
Erasing FRP... OK
The Following User Says Thank You to donniegalaxy2 For This Useful Post:
Old 02-27-2018, 21:53   #9 (permalink)
Member: 92260
Thanks Meter: 802
Ok, I got it...
Firmware version G930V-VRU4API3 v6.0.1 is considered "old", but newer ones starting with VRU4BQxx v7.0.0 DO NOT have the ADB-enable option in the maintenance menu, so you must use either a combination or eng-boot to enable adb. This will soon be closed with the introduction of the new RMM security which works independantly from OEM-Unlock... basically it won't let you flash anything else but official stock firmware ... it's gonna be a bitch !! FYI
Old 03-31-2018, 14:52   #10 (permalink)
Member: 2349214
Thanks Meter: 4
Thanks it worked ; first put phone in download mode then hold volume down and power until the phone restart , enable debugging using home button finally use z3x to rest frp
Old 03-31-2018, 16:32   #11 (permalink)
Member: 2498409
Thanks Meter: 99
simple way just write engroot g930v p any vaarriat simple reset frp
Old 06-14-2018, 17:24   #12 (permalink)
Member: 2280652
Thanks Meter: 2
ok 100% thank you good job
Old 06-30-2018, 11:57   #13 (permalink)
Member: 1139461
Sonork: 100.1580353
Thanks Meter: 125
[ 6/30/2018 4:10:49 PM ] Software version: 32.7
[ 6/30/2018 4:10:50 PM ] You must activate ADB before reset FRP Yes
[ 6/30/2018 4:10:51 PM ] Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes
[ 6/30/2018 4:10:52 PM ] Waiting ADB device... OK
[ 6/30/2018 4:10:53 PM ] Reading phone info...
[ 6/30/2018 4:10:54 PM ] Model: SM-G930V
[ 6/30/2018 4:10:54 PM ] Android version: 6.0.1
[ 6/30/2018 4:10:54 PM ] PDA version: G930VVRS4APH1
[ 6/30/2018 4:10:55 PM ] CSC version: G930VVZW4APH1
[ 6/30/2018 4:10:55 PM ] Phone version: G930VVRS4APH1
[ 6/30/2018 4:10:55 PM ] Product code: Not Active
[ 6/30/2018 4:10:56 PM ] CSC country code: USA
[ 6/30/2018 4:10:56 PM ] CSC sales code: VZW
[ 6/30/2018 4:10:56 PM ] Phone SN: RF8H81T891J
[ 6/30/2018 4:10:57 PM ] IMEI: 3534250---------
[ 6/30/2018 4:10:57 PM ] HW version: REV0.6
[ 6/30/2018 4:10:57 PM ] RF cal date: 2016.08.18
[ 6/30/2018 4:10:58 PM ] Chip name: MSM8996
[ 6/30/2018 4:10:58 PM ] Modem board: MSM8996
[ 6/30/2018 4:10:58 PM ] Security patch: 2016-09-01
[ 6/30/2018 4:10:59 PM ] Boot Warranty bit: 0
[ 6/30/2018 4:10:59 PM ] Bypass FRP... OK
[ 6/30/2018 4:11:01 PM ] For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Old 06-30-2018, 16:27   #14 (permalink)
Fragga's Avatar
Member: 1507693
Thanks Meter: 111
ANY SOLUTION for latest firmwares (G930VVRU4CRE5_VZW4CRE5) ? I am failing to remove FRP ,I cant downgrade (SW REV CHECK FAIL)
Old 06-30-2018, 17:38   #15 (permalink)
Member: 453823
Thanks Meter: 20
The Following 2 Users Say Thank You to vapyo_2005 For This Useful Post:
Page generated in 0.40522 seconds with 7 queries
