10-17-2010, 10:39 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: GOOD
Member: 388862 Status: Offline Thanks Meter: 107 | S7550 read Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press on 3 sec power button Booting... OK Found bad block Remaped bad block 82 -> 1002 Remaped bad block 528 -> 1003 Timeout Read FULL - false Elapsed time: 3049 second, sw ver: 3.4.0068 |
10-18-2010, 08:19 | #3 (permalink) |
Member: 388862 Status: Offline Thanks Meter: 107 | This is S7550 * How to use Download Mode 1. Turn off the target phone!!! 2. Select COM Port(USB or UART) , Baud Rate. 3. Push the Start Button. 4. Turn on the target phone!!! * Connecting to target phone Try to open COM3 >Success!! - Turn on the target phone immediately!!!! Listen for the BOOT signal > > > OK Send the Download start signal > > > OK Listen for the Download start ACK signal > > > OK * NAND Flash Driver Download preloader downloading > > > OK NAND Flash driver downloading > > > OK Flash Type Checking > > > OK NAND Bad block check > > > 2 Bad block found --------------------------------------------------------- P.Block[82] ---> S.Block[1002] P.Block[528] ---> S.Block[1003] --------------------------------------------------------- OK UART Download Mode > > > Available |
10-18-2010, 08:21 | #4 (permalink) |
Member: 388862 Status: Offline Thanks Meter: 107 | This is S5620 * How to use Download Mode 1. Turn off the target phone!!! 2. Select COM Port(USB or UART) , Baud Rate. 3. Push the Start Button. 4. Turn on the target phone!!! * Connecting to target phone Try to open COM3 >Success!! - Turn on the target phone immediately!!!! Listen for the BOOT signal > > > OK Send the Download start signal > > > OK Listen for the Download start ACK signal > > > OK * NAND Flash Driver Download preloader downloading > > > OK NAND Flash driver downloading > > > OK Flash Type Checking > > > OK NAND Bad block check > > > 128 Bad block found --------------------------------------------------------- P.Block[55611] ---> S.Block[44957] P.Block[21532] ---> S.Block[13168] P.Block[23142] ---> S.Block[29090] P.Block[36561] ---> S.Block[53505] P.Block[43864] ---> S.Block[53877] P.Block[24642] ---> S.Block[61115] P.Block[62382] ---> S.Block[56805] P.Block[23843] ---> S.Block[15326] P.Block[13307] ---> S.Block[35899] P.Block[42880] ---> S.Block[24077] P.Block[54388] ---> S.Block[26031] P.Block[9202] ---> S.Block[45478] P.Block[45013] ---> S.Block[56063] P.Block[17721] ---> S.Block[28645] P.Block[53086] ---> S.Block[55931] P.Block[24297] ---> S.Block[64444] P.Block[18297] ---> S.Block[35059] P.Block[27194] ---> S.Block[1545] P.Block[44489] ---> S.Block[53966] P.Block[63360] ---> S.Block[58097] P.Block[45009] ---> S.Block[32250] P.Block[26352] ---> S.Block[5091] P.Block[31697] ---> S.Block[65341] P.Block[57267] ---> S.Block[5663] P.Block[58553] ---> S.Block[11822] P.Block[16687] ---> S.Block[56245] P.Block[30841] ---> S.Block[63868] P.Block[13023] ---> S.Block[15171] P.Block[1019] ---> S.Block[52661] P.Block[21785] ---> S.Block[56303] P.Block[30565] ---> S.Block[21037] P.Block[62874] ---> S.Block[56691] P.Block[31219] ---> S.Block[27414] P.Block[12351] ---> S.Block[55454] P.Block[14041] ---> S.Block[57136] P.Block[21077] ---> S.Block[33275] P.Block[48952] ---> S.Block[18890] P.Block[49450] ---> S.Block[61830] P.Block[22638] ---> S.Block[43430] P.Block[41903] ---> S.Block[13625] P.Block[56297] ---> S.Block[31004] P.Block[5541] ---> S.Block[61274] P.Block[64974] ---> S.Block[46325] P.Block[42863] ---> S.Block[65099] P.Block[60731] ---> S.Block[52205] P.Block[47391] ---> S.Block[60968] P.Block[36136] ---> S.Block[31380] P.Block[44025] ---> S.Block[8590] P.Block[43119] ---> S.Block[38840] P.Block[50145] ---> S.Block[35976] P.Block[63954] ---> S.Block[15761] P.Block[5715] ---> S.Block[39279] P.Block[46468] ---> S.Block[46335] P.Block[29052] ---> S.Block[30686] P.Block[7789] ---> S.Block[55766] P.Block[59902] ---> S.Block[53077] P.Block[24379] ---> S.Block[48874] P.Block[63557] ---> S.Block[26507] P.Block[31439] ---> S.Block[16793] P.Block[47523] ---> S.Block[25331] P.Block[62437] ---> S.Block[13278] P.Block[31563] ---> S.Block[63320] P.Block[62902] ---> S.Block[48807] P.Block[20076] ---> S.Block[32732] P.Block[15667] ---> S.Block[29828] P.Block[47635] ---> S.Block[18331] P.Block[26879] ---> S.Block[59354] P.Block[52154] ---> S.Block[63677] P.Block[16374] ---> S.Block[44888] P.Block[28157] ---> S.Block[54267] P.Block[27598] ---> S.Block[51239] P.Block[65220] ---> S.Block[29628] P.Block[30105] ---> S.Block[16831] P.Block[44260] ---> S.Block[24443] P.Block[52252] ---> S.Block[23801] P.Block[28666] ---> S.Block[46231] P.Block[59651] ---> S.Block[30648] P.Block[28119] ---> S.Block[47941] P.Block[55191] ---> S.Block[55224] P.Block[40924] ---> S.Block[40237] P.Block[19101] ---> S.Block[39773] P.Block[65124] ---> S.Block[21125] P.Block[63187] ---> S.Block[62424] P.Block[31400] ---> S.Block[33657] P.Block[47990] ---> S.Block[31443] P.Block[1403] ---> S.Block[61] P.Block[59635] ---> S.Block[40183] P.Block[57318] ---> S.Block[12672] P.Block[26098] ---> S.Block[12454] P.Block[24075] ---> S.Block[9573] P.Block[24073] ---> S.Block[63577] P.Block[1691] ---> S.Block[3421] P.Block[30101] ---> S.Block[32564] P.Block[39355] ---> S.Block[42275] P.Block[18851] ---> S.Block[14191] P.Block[55187] ---> S.Block[12589] P.Block[52047] ---> S.Block[52125] P.Block[42499] ---> S.Block[50839] P.Block[63787] ---> S.Block[28458] P.Block[26574] ---> S.Block[10645] P.Block[16344] ---> S.Block[52661] P.Block[61234] ---> S.Block[63815] P.Block[57291] ---> S.Block[30022] P.Block[13849] ---> S.Block[29045] P.Block[42623] ---> S.Block[28086] P.Block[35233] ---> S.Block[42432] P.Block[47855] ---> S.Block[44799] P.Block[63179] ---> S.Block[58048] P.Block[61275] ---> S.Block[38842] P.Block[4429] ---> S.Block[50668] P.Block[3691] ---> S.Block[58343] P.Block[62420] ---> S.Block[37677] P.Block[48653] ---> S.Block[42037] P.Block[410] ---> S.Block[1655] P.Block[52958] ---> S.Block[64955] P.Block[36120] ---> S.Block[64886] P.Block[45014] ---> S.Block[30526] P.Block[14887] ---> S.Block[14824] P.Block[65125] ---> S.Block[60375] P.Block[15358] ---> S.Block[19775] P.Block[15951] ---> S.Block[11474] P.Block[54585] ---> S.Block[57740] P.Block[39734] ---> S.Block[62953] P.Block[23508] ---> S.Block[48889] P.Block[1883] ---> S.Block[15677] P.Block[48292] ---> S.Block[58876] P.Block[32245] ---> S.Block[5027] P.Block[36275] ---> S.Block[28511] --------------------------------------------------------- OK UART Download Mode > > > Available |
05-22-2011, 17:15 | #9 (permalink) |
Freak Poster Join Date: Nov 2007 Location: Bangladesh
Member: 638097 Status: Offline Sonork: 100.1649741 Thanks Meter: 43 | Sir, I m trying to unlock s7550 by z3x, it sayes that phone is unlocked but when i turn it on it say entre phone lock cod.i tryed by - 00000000 but it say wrong cod . what to do sir ? |
05-23-2011, 08:26 | #10 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,554 | Quote:
2.1 In tread body use full description of problem not waste our and your time while we will ask this: - phone models, - status of phone before any job with phone, - phone firmware, - cable which you use, - if possible - screenshots or full, not cutted log of each jobs. 2.2 Posts with "up, up" or "??????????????" or other comments like this will be deleted and after 3 post this acces to z3x section will be blocked for spammer. 2.3 NEVER USE SN OF Z3X CARDS IN FORUM OR SCREENSHOTS. IF WE WILL SEE ANY SN - THIS SN WILL BE BLOCKED FOR 2 WEEKS 2.4.IF YOU WANT post ANSWER IN THREAD, your answer should touch tread name only. 2.5 POSTS "I HAVE SAME PROBLEM" - WILL BE deleted. IF YOU HAVE YOUR OWN PROBLEM - OPEN YOUR OWN TREAD. 2.6to be continue | |
Eeprom reading | KLImax | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-22-2011 15:55 |
read eeprom write eeprom, what do i need? | jonthe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 12-08-2010 06:24 |
unable to reads phone type.. | Rosshire | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 07-17-2000 15:55 |
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? | MyKe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-26-1999 14:31 |
