11-16-2017, 10:28 | #1 (permalink) |
Junior Member Join Date: Jan 2008 Location: surat
Member: 674540 Status: Offline Thanks Meter: 2 | Samsung S8 G950F Fainally UNLOCK With Z3X Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Read Codes via Server Selected model: SM-G950F Software version: 29.8 Checking Login and Password... OK Ballance: 40 crd. You have 40 credit(s) left. This opreratin takes 5 credits.Continue? Yes Searching Samsung modem... detected COM47 Reading phone info... OK Model: SM-G950F AP version: G950FXXU1AQDG CSC version: G950FOVF1AQDG CP version: G950FXXU1AQDG Product code: VOD Phone SN: RF8J62A7LJJ Unique number: CE0517158869783901 Searching Samsung diag port... detected COM46 Reading phone info... OK CP version: G950FXXU1AQDG CP build: Apr 24 2017 17:54:46 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 95906309 NET lock: 70507302 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.8 |
