Old 01-31-2013, 15:31   #1 (permalink)
kumar_gsm_kumar's Avatar
Member: 230569
Sonork: 1608865
Thanks Meter: 271
Samsung s8530 successfully imei change with with z3x box
YOU MUST TO FLASH PATCHED FIRMWARE FIRST
uart cable:
1. Phone must be powered on.
2. Connect the phone to UART port.
3. Choose correct COM port in port settings
4. Press "Repair" button.
5. In opened window fill fields what you need to repair.
6. Press "OK".
usb cable:
1. Turt phone on.
2. Enter *#782872# it will switch mode to Qualcomm
3. Connect phone to PC, install drivers if needed.
6. Press "OK".
Selected model: S8530
Selected port: COM5 Z3X BOX Serial Port
Selected port speed: 115200
Searching Samsung USB flash interface... detected COM21
Erasing BOOT_LOADER.mbn... OK
Sending BOOT_LOADER.mbn... OK
Erasing Dbl.mbn... OK
Sending Dbl.mbn... OK
Flashing BOOT files done (time - 00:00:02)
Wait, reset...
Erasing APPS... OK
Sending APPS... OK
Flashing done (time - 00:00:42)
Done with Samsung Tool v.13.9
Selected port: COM15 SAMSUNG Mobile USB Serial Port
Searching Samsung modem... detected COM14
Reading phone info...
Model: GT-S8530
Country code: OPENÇâ
Cal date: 2011-07-06
Factory SW: S8530DDKF1_ODDKF1
Unique number: 86230000718630
Memory phone: KAC007021M(S8530)
Software version: S8530DDLC2/S8530ODDLC2
IMEI: 3588880411xxxx/x
Product code: GT-S8530BAUINU
Bypass MSL... OK
Repairing IMEI... OK
Repair done
Reseting... OK
The Following User Says Thank You to kumar_gsm_kumar For This Useful Post:
Old 08-12-2013, 21:03   #2 (permalink)
imrankhan0143's Avatar
Member: 1796401
Sonork: 100.1623409
Thanks Meter: 56
uart cable:
6. Press "OK".
usb cable:
1. Turt phone on.
6. Press "OK".
Wait, reset...
Erasing APPS... OK
Sending APPS... OK
Model: GT-S8530
Bypass MSL... OK
Repair done
Reseting... OK
bro. first check your imei and post result
i am agree with u
Bypass MSL... OK
Repair done
Reseting... OK
but imei not repair
BR.
IMRAN KHAN
Old 09-01-2013, 10:34   #3 (permalink)
Member: 1796401
Sonork: 100.1623409
Thanks Meter: 56
USE RIFF
1-Goto DCC.READ/WRITE Page
2-select "Auto Full Flash size"...select ROM1....Then press "Erase"
3-resurrect phone..
4-flash with multiloader v.5.65 any firmware
5-Repair IMEI Not Active by another tool's
100000000000000% WORKING SOLUTION
Old 11-19-2013, 13:49   #4 (permalink)
deepakkumar39's Avatar
Member: 1464245
Thanks Meter: 176
Bypass MSL... error
Done with Samsung Tool v.16.1
Old 11-18-2014, 01:12   #5 (permalink)
Member: 1370384
tnx bro.... very nice....
Page generated in 0.17567 seconds with 8 queries
