10-26-2017, 15:00 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: The Himalayan Kingdom "NEPAL" Age: 40
Member: 580145 Status: Offline Sonork: 100.1627342 Thanks Meter: 50 | Samsung SCV35 Read Codes Via Server ok, unlock failed. Code: UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SCV35 Selected port: COM1 Communications Port Software version: 29.5 Checking Login and Password... OK Ballance: 45 crd. Waiting ADB device... OK Reading phone info... Model: SCV35 Android version: 7.0 Product code: SM-G955JZSAKDI Phone version: SCV35KDU1AQF2 PDA version: SCV35KDU1AQF2 CSC version: SCV35KDI1AQF2 CSC country code: JP CSC sales code: KDI HW version: REV08 Phone SN: R58J5629DHY Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-06-01 RF cal date: 2017.05.26 IMEI: 356380080802016 Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM25 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 68529170 NET lock: 00000000 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.5 WBR Yash_npj Last edited by Yash_npj; 10-26-2017 at 15:06. |
10-26-2017, 15:47 | #2 (permalink) | |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Bro flash firmware sc-02h and then unlock after that resoft original firmware Quote:
